20 Most Recent La Crosse Technology La Crosse S98642 Wireless Atomic Color Weather Questions & Answers
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
La Crosse... | Answered on Nov 04, 2013
yes it does. lithium batteries are preferred
Measuring Tools... | Answered on Jun 16, 2019
1. Disconnect the test leads from any energized circuit and then from the instrument.
2. Turn the range switch to the "OFF" position
3. Slide off the back case battery cover.
4. Remove the battery from the compartment and unsnap the battery connector.
5. Replace the battery with a 9V transistor type battery (NEDA # 1604), For maximum battery life, alkaline cells are recommended.
6. Reverse the above procedure to complete replacement.
Measuring Tools... | Answered on Jun 15, 2019
Have you tested the rain gauge using the calibration procedures on page 21 of the manual? Specifically confirming that the bucket is emptying about every 25 drops.
https://www.acurite.com/media/manuals/01536-instructions.pdf
Measuring Tools... | Answered on Jun 06, 2019
no info -generic answer check with manufacturer -owners manual online search uging make and model of mystery unit
Measuring Tools... | Answered on Jun 05, 2019
La Crosse Technology La Crosse S98642 Wireless Atomic Color Weather Logo
3 questions posted
Top La Crosse Technology Measuring Tools & Sensors Experts
ka4iup
ka4iup
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • La Crosse Technology Measuring Tools & Sensors
Most Popular Question
remote sensor tx14th lcd b started
  • Measuring Tools & Sensors
