Got E21 and replaced the UIB and the controller. Thought it was all OK but after an hour of the stovetop working, it went back to E31. What's going on? I need this unit to work in our cafe!
The F31 error code means that the control board detects the oven temperature probe circuit is shorted. If the sensor tests good, then you could have a bad control board or a short in the wiring.
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
SOURCE: Frigidaire Gallery Self Cleaning Oven
F1 code on frigidaire is bad EOC (clock) Try shutting breaker off 20-30mins see if it resets itself.
SOURCE: self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "was surprised at such a quick response...needed additional information to provide a better solution...very grateful for the assistance"
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Hi michell51238 - From what you are describing it sounds like the range may possibly have a faulty light switch or wiring failure that only a professional can repair. I personally recommend consulting a certified technician for a proper diagnosis and to move forward accurately.
Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
Within my research I was able to locate code "F3" which indicates a possible error with the oven probe. It is recommended that a Service Specialist assist you with further diagnosing the issues.
