SOURCE: unable to finalise
For some reason one of the discs that i have recorded on will not let
me finalise. When i put the disc in it says recording disabled and then
i go to the finalise menu and the finalise selection is unhighlighted.
How can i fix this so i can finalise the disc and use it on my computer?
thanks
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
SOURCE: how to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
SOURCE: Sony Handycam DCR-DVD 202E
i am getting a disk access error in sony camcorder..Not able to record any further..pl. help
