20 Most Recent Durabrand DU1301 TV Questions & Answers
You should have a remote control to select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Durabrand DU1301... | Answered on Nov 06, 2015
0020 0045 0078 0091 0104 Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Durabrand DU1301... | Answered on Apr 29, 2015
Not knowing how old the unit is hampers me a bit. But, if I were in your position and the TV is no longer covered by warranty, I would just get a universal remote that will work with your TV. Most universal remotes will replace your remote and all of the old one's functions. Most places where you can purchase universals will let you check as to whether or not it will work with your make and model TV.
You can also try to get a replacement remote from the TV maker but those can be expensive when compared to universals. But at the same time, you will be sure that you can have a remote that has all functions.
Durabrand DU1301... | Answered on Oct 14, 2014
This is how I did mine ; first try to view a chanel that is locked. on the tv front panel turn the volume all the way down with the button, not the remote.While pushing the -volume down on the tv press 0 on the remote .That is it .
Durabrand DU1301... | Answered on Jun 15, 2014
Hello, Do you have users manual?
Durabrand DU1301... | Answered on Jun 01, 2014
Diagrams are in PDF, and cannot include it by this windwo. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Durabrand DU1301... | Answered on Dec 25, 2013
The closed caption just suddenly appeared on my screen with no buttons pressed. It won't turn off. I no longer have the original remote for this Durabrand 13" DU1301 TV . I was using the Time Warner Cable remote and have a basic cable box attached to the TV. Everything was fine until suddenly with no buttons pushed the closed caption came on. Is there anything sort of buying a new tv to fix this
Durabrand DU1301... | Answered on Jan 13, 2013
Go on the brand of Durabrands site if you need help from him.
Durabrand DU1301... | Answered on Sep 29, 2012
I went and got a RCA 3 universal 10463 code remote typed in code and it worked....! heres 10180 10178 10171.
Durabrand DU1301... | Answered on Sep 25, 2012
Hello
The fault you describes is due to low signal strength. If tuner of the said TV is faulty, this type of snow interference will occur too. Just check for good firm connection to its antenna terminal. If it is Ok, check the continuity of the cable used with antenna. Check the orientation of yagi antenna if used outside. If all are OK, and nothing help you, just replace its tuner with same type and number. Tuner is a small metal box type component can be seen soldered directly to the main printed circuit board inside. Usullay, its one terminal will come out as antenna IN of the TV, to which you connects the external antenna or cable. You must have a concept of soldering and desoldering to replace it, and must have a knoledge in electronics too. OK.
Durabrand DU1301... | Answered on Jul 31, 2011
try checking for defective speaker or try setting the system control first
Durabrand DU1301... | Answered on Jul 16, 2011
Try the codes for Orion and Sansui.
Durabrand DU1301... | Answered on Apr 02, 2011
I have just got a duraband tv.. I bought a remote RCA wal-Mart 7.99 it has the codes and it worked!!!!
Hello
Four digit universal remote codes for duraband are:
0189 0135 0157
0153 0254 0458 0217
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV WITH ITS FRONT PANEL POWER CONTROL SWITCH EACH TIME before trying an other code.
OK.
Durabrand DU1301... | Answered on Feb 20, 2011
Durabrand DU1301 TV Logo
73 questions posted
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Durabrand Televison & Video
Most Popular Question
need change input from rear front remote
  • Televison & Video
