LG GSA-E10L (8801031212552) DVD±RW Dual Layer Burner Logo
Posted on Aug 03, 2009
I cant use my lg external dvd drive on linux mint 7.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
2342
Points
6
Hi mcasey82,
Yes lg external dvd drive would work with just about any latest linux distribution, if your user account is a member of the plugdev linux groupthe drive will automatically appear on the desktop after you plug the drive from the usb slot
you can verify the plugdev group members by issuing a command cat /etc/groups from the command terminal
user@localhost# cat /etc/groups | grep plugdev
if your current username is not a member, you add by issuing a usermod command
user@localhost# usermod -g plugdev username
I have a e system Ei 106 i cant get to log in screen just configuring updates then restarts and back to same screen help please as dont want to lose all my work and photos
Have you tried letting it finish configuring updates? I have seen Windoz PCs have to run overnight sometimes, due to the awful M$ coding.
If you are computer literate, or have a friend who is, you can use a Linux live CD/DVD/USB stick to access your HDD. I'd use Knoppix if you are experienced, Linux Mint or Ubuntu if semi-PC literate.
If your hard drive didn't croak, all your data is still there. You can use the Linux CD/DVD to move it to an external USB drive or USB stick. You may be able to repair the Windoz installation via the Linux disk too. Unfortunately, it would take a novel to tell you how on FixYa.
Hope this helps point you in the right direction.
My help &support can't start on my windows 7 home premium
download a copy of linux mind and burn it with iso. then boot from the cd , get a external hard drive and back all you stuff manually. youtube linux mint.the resintall windows 7 again
2answers
I want to Install Linux Mint on ThinkCentre M55p Series Type 8811
If it Has Windows 8 or 8.1 you might need a new Hard Drive to do this. Windows 8 and 8.1 are encrypted so you can't use Linux of any type. If it has Windows XP try Linux Mint 13 "Maya", the replacement for win xp, If Windows 7 64 bit: Try Linux Mint 17.1 *Rebecca"
My device is not being recognized
It looks like Linux Mint is not a supported OS.
Buffalo Americas
Only the following are supported:
Windows 8 (32-bit/64-bit), Windows 7 (32-bit/64-bit), Windows Vista (32-bit/64-bit), Windows XP, Mac OS X 10.5 or later
The Linux Mint Dev Team may be working on a solution, but this is not something Buffalo will help you with.
Bought used need to by pass password
You didn't say what OS you are using.
1.To try and remove the password protection you can power off the PC.
remove the side panel and then remove the battery. Leave it for 10 minutes, refit the battery and then power up the PC. The password protection may have been removed.
2. Or at start up, enter the bios settings. You may be able to disable the password from within the settings.
3. If you're not bothered which OS you use, try a new install of XP or Windows 7.
If you don't have XP or Windows 7, ask a friend to download linux and burn it onto a dvd for you(or put it onto a usb flash drive). Put the linux dvd into your dvd drive and restart the computer. You will have the choice of completely erasing Windows, or installing Linux alongside Windows.
Linux is free. It will do everything Windows can do. Linux comes with its own version of 'Office'. The best free versions of Linux are Ubuntu or 'Mint'.
You can download Ubuntu here: http://www.ubuntu.com/download/desktop
Webcams do NOT work in Linux. Apart from that, Linux will do everything Windows can do (but free!) and you won't ever get a virus.
Hi. I bought a notebook where windows 7 has been installed. I want to install Linux Mint, but it does not work. I was able to shrink the drives with Windows Disk management, but when I insert a Linux...
You will need to hit the key function required to choose your boot media. Example, F2, F12. Choose the DVD drive. The Linux OS should format the drive area for the installation and install a boot manager that will allow you to choose which operating system that you want each time you turn it on.
1helpful
5answers
I'd like to install a version of Linux on my laptop. I am a beginner; what ill fit me and how to install it?
For a beginner the best version of Linux for a laptop remains UBUNTU. But you can count on LINUX MINT and the latest version of it is called JULIA.
You can find UBUNTU here. And LINUX MINT here.
The BOTH can be installed via installation DVD and for both also you can TRY BEFORE INSTALL, meaning you can run the version of LINUX LIVE, taste and test it before you will install it on your hard drive.
2answers
I cant reboot my computer without a disc because i dont have one
If you have the Windows XP / Vista / 7 DVD, that would be your disk. If you don't, you could just as well borrow a copy off a friend as long as you have your own product key. Once you have the disk you can boot from the DVD.
My acer 5720 is dead battery is good and ac is connected it just wont start
The problem is with the corrupted boot files .In my opinion you have one solution
Steps for solution
1. Download an operating system called ' Linux mint ' which can be installed in the pen drive having minimum 4 gb capacity . Using this operating system you can access the computer .
2. Copy the file and folders to an external storage device (external hard disk, pen drive etc..)
3. Reinstall the operating system ( XP,Vista ,Window 7,Ubuntu etc )
Hope you be successful
4answers
Install Linux OS
I would recommend installing Linux Mint LXDE, Cinnamon or KDE, which is a free OS available for free download from http://linuxmint.com Cinnamon and KDE are full featured, XFCE is streamlined and slightly faster and a better choice for older computers with less memory and/or storage space. All versions come with Firefox and LibreOffice full Office Suite, capable of saving and reading files in the popular MS Office formats like .doc, .docX, .ppt and xls.
Linux comes with almost everything necessary to begin using the computer immediately after installing the OS.
To install it on a netbook or notebook computer, I'm assuming you don't have a DVD optical drive so you have to install it from a USB thumb drive. If you have a DVD optical drive, I would still recommend installing it from the USB thumb drive, ... it's more reliable and less prone to failures from trying to burn a DVD on old, dirty or out-of tolerance equipment.
First download the .iso file on another computer. If you're not sure if your computer is 32-bit or 64-bit, you can use the 32-bit for both, or try the 64-bit - if that doesn't work, use the 32-bit.
Use a free program to create a bootable USB using the .iso file. (You can't just copy the file to the USB drive) ... I'd recommend using Active ISO Burner from NTFS.com ... here's the download link ... http://www.ntfs.com/iso-burning.htm (You should be using at least an 8 GB size thumb drive).
Once you've created the bootable USB drive from the .iso file, you should be able to insert it and start the computer and see the Linux Mint startup screen. It will come up in LIVE mode, without installing itself, so you can try it out.
If you want to install it, make sure you are connected to the Internet and have your AC power adapter plugged in.
If the computer doesn't come up with the Linux screen, you probably just need to reset your BIOS boot order so it boots from the USB driver first. Plug in the USB drive and start the computer. Look of instructions for set up or boot order, usually pressing F2 while the computer is starting. Follow the directions to move the USB to the top of the boot devices, i.e. about the hard drive. Save changes and restart the computer. It should now boot from the USB. If you have trouble doing this or burning the bootable USB, you might have a geek friend or relative that can help or do it for you.
When the LIVE mode comes up, it displays the Linux desktop with an Install icon. If you double click the Install Icon you will begin the installation process and just follow the simple prompts and create a password when prompted.
Linux never requires anti-virus and does not become infected. You can visit the main http://linuxmint.com website and download the .PDF manual if you are interested.
Your computer is probably 64-bit, but if not, there is also a 32-bit version available for download.
The image shown below is from my Acer and is Linux Mint KDE, which is also available from the same website and similar to LXDE, but more full-featured. All Google programs I know of are available for Linux, since Google uses 100% Linux. Android is Linux also.
Once you install your Linux, you'll want to run the Update Manager to get the latest updates.
On my Acer netbook I have 3 Linux OS's installed. Linux Mint Cinnamon 64-bit, Linux Mint KDE Cinnamon 64-bit and Linux Mint XFCE 64-bit. I select the OS I want at startup when the computer starts.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
