20 Most Recent Acer Aspire 5720-6661 Notebook PC Questions & Answers
3answers
Downloaded movie wont play
fist of all make sure that the file type of the movie is compatible with your computer's software and that its not corrupted and the download was complete, if you downloaded it from lime wire or a program alike it would be a common problem, try downloading another movie and if the problem persists post it here,
hope i could help at all, help me out give me a thumps up,
7/25/2022 9:29:42 AM • Acer Aspire... • Answered on Jul 25, 2022
3answers
Hi there. like many people, i wish to connect my
blu ray disc are read only for a new dvd blue ray device... buy a blue ray dvd device... that is the solutions to your and too expensive...
3/14/2020 1:24:18 AM • Acer Aspire... • Answered on Mar 14, 2020
3answers
Fingerprint sensor not detected in acer 5738
insert the acer 5738 driver cd and right click>open>xp>finger... click and install, then right click on my computer>manage>device manager> here check "personal identification devices", authenTec Inc should appear if installed properly.
3/7/2018 9:02:21 AM • Acer Aspire... • Answered on Mar 07, 2018
2answers
I can't recevie any files
If you are using the MS bluetooth stack, you must explicitly prepare your notebook to receive the file. You must have bluetooth icon in the notification area. Right click it and select something like 'Receive file' (sorry for not being more specific, since mine is in Portuguese). Only then, send the file from your mobile.
Hope it works for you.
Just my 2 cents...
Regards, Carlos
12/24/2016 3:11:21 AM • Acer Aspire... • Answered on Dec 24, 2016
3answers
My acer which windows 7 can i put in it 32 or 64 modle# ICL50 Aspire 5720z
Hello, there are drivers listed for Windows 7 32bit. Hope this helps. Source: Windows 7 32 bit Drivers Chat Live Facebook
1/26/2016 3:15:34 AM • Acer Aspire... • Answered on Jan 26, 2016
6answers
My acer aspire 5738g shutdown while i plaay agame
You either overloaded the processor or the available RAM. Also with these laptops and high end games...it is very easy to overheat them unless they are on a cooling pad with another external fan blowing cool air over them, without it they will shut down due to thermal overload....this is to keep them from melting something. Try checking with the support driver page for your laptop and see if there is a BIOS update that addresses the algorithym for fan speed, then pull the heat sink from the processor, clean everything up and apply a good thermal paste compound, then blow out all the airvents and make sure there are no restrictions.
9/11/2015 8:18:00 AM • Acer Aspire... • Answered on Sep 11, 2015
Touchpad
put your mouse over the item then press down and hold left key then use your finger on the pad and just slide your finger across the pad,then when you get to were you want the item togo then just lift your finger off and let go of the left key.
4/6/2015 10:37:53 PM • Acer Aspire... • Answered on Apr 06, 2015
2answers
Acer Aspire E1 510P laptop - only just received, put in nick name and made up a password and tried to set up at home which has a different p.c. user name etc. It won't connect to the net and keeps sa
goto your start menu and write in,, restore it should give you the options that you need,thats the easy way for you todo it.
3/29/2015 7:40:51 PM • Acer Aspire... • Answered on Mar 29, 2015
My Acer serial number rubbed off. How can I get it?
it is written on the original receipt too..
3/6/2015 10:49:13 PM • Acer Aspire... • Answered on Mar 06, 2015
Let our Experts solve your
The Yahoo Chat is defective.
3/6/2015 10:46:31 PM • Acer Aspire... • Answered on Mar 06, 2015
Turns off shortly after turning on
Is this when connected to power source or on battery? If it is on battery the battery may need to have its memory refreshed. Turn the 5720 off, remove the battery, hold the on/off button down for 15 seconds and when done put it back together and turn it on. Good Luck
3/4/2015 9:27:46 AM • Acer Aspire... • Answered on Mar 04, 2015
How to eject sd card from laptop
just push it in and it should pop out
2/3/2015 1:56:05 AM • Acer Aspire... • Answered on Feb 03, 2015
The cursor moves by itself during typing.
I have found this is usually the small button in the middle of the keyboard (mouse button) I have tried some software to remove this problem but it did not on my laptop I ended up carefully removing the key board and disconnecting the two wires that go to the button My cursors kept moving across the screen
9/5/2014 5:28:32 PM • Acer Aspire... • Answered on Sep 05, 2014
Repair dvd error
Reload software
8/26/2014 2:49:10 PM • Acer Aspire... • Answered on Aug 26, 2014
Touchpad drag and drop from surveys
This can be accomplished a couple of ways. Depending on the model of your computer there may be a pressure sensitive switch under the mouse pad that pressing a little harder will actuate. Another method is there might be 'virtual' mouse buttons on your trackpad. Put one finger in the flower left corner and drag on the pad with another. Finally, there is a setting for a double click drag and drop. Tap the mouse pad twice and on the second tap keep your finger on the pad and move it. Good luck!
4/15/2014 10:32:41 PM • Acer Aspire... • Answered on Apr 15, 2014
2answers
How can i use finger print option in acer 5738Z
You have to first log into your account manually and by going to fingerprint application save you finger print within that application and then it will automatically get associated with you account and then only it will work
4/12/2013 11:14:11 AM • Acer Aspire... • Answered on Apr 12, 2013
2answers
Webcam
If you go to your start menu, look for a programme called 'acer crystal eye webcam' and that will bring up your webcam programme.
It is not in the folder 'Acer crystal eye webcam' though, just 'Crystal eye webcam'.
start \ all programmes \ Crystal Eye Webcam \ Crystal Eye Webcam.
If this proves fruitless, type webcam into the search option at the bottom of your start menu and look for the crystal eye webcam.
If these do not work, then look in your control panel to make sure it is installed. If not, contact company, they have a good customer service standard (from my experience)
3/24/2013 2:12:06 AM • Acer Aspire... • Answered on Mar 24, 2013
2answers
How do I turn the
Please press the wireless button at the location shown on the upper right corner of the keyboardtelehelp.jpg
2/1/2013 1:45:20 AM • Acer Aspire... • Answered on Feb 01, 2013
Acer Aspire 5720-6661 Notebook PC Logo
348 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
just recovered
  • Computers & Internet
