SOURCE: atech weather station with
First thing to do is remove all batteries. After you do that, insert the new batteries into your receiver unit. After a few seconds, insert the batteries into first sensor (-> ch 1) After first sensor has connected (beep from receiver) insert the batteries into second sensor. Click on the link below to access the user manual for the WS303G
http://www.atech.hk/
SOURCE: I have a Sharp SPC502
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
SOURCE: No longer shows temp (indoor
Mine did the same thing. I just had to replace the batteries in the main unit and it is working again. Good luck!
SOURCE: Ultronic clock. weather station, where does it get the temp
There must be an outside sensor somewhere, usually a small white plastic box, some have a display, some don't.
