Dryers Logo
Veronica Greer Posted on Oct 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does my hotpoint dryer model #HTDX100EM8WW have a thermostat reset?
Chris Huff
Level 3:
Top Expert:
  • Hotpoint Master 6,289 Answers
  • Posted on Oct 15, 2018
Chris Huff
Hotpoint Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020468
Points
74913
Some thermostats such a cycling thermostat are resettable and automatically cycle on and off based on your temperature setting choices. Others such as a thermal fuse are not resettable and will blow if dryer gets to hot. That type has to be replaced after determining and correcting why it overheated.
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 • Dryers
Where is the reset button on a CDT00 dryer
I assume you are speaking of a Hotpoint electric dryer based upon the model and question. There is no reset button on this dryer. Does it not heat or does it not tumble? Typically with these dryers, it is a thermostat that has failed if you are having a heat issue. Check this website;
https://www.youtube.com/watch?v=sfGInKA3yp8.
Jan 15, 2015 • Dryers
WERE IS THE RESET BUTTON ON HOTPOINT DRYER CDT 80
Not sure if all dryers have a thermostat reset. You can check your model (which might be CTD80 and not CDT80). Usually it can be reset if there is a small hole in the middle of the device where you can insert a tooth pick and press it.
Location of thermostats is at the back. Make sure the power chord is unplugged from the wall.
See this youtube video.
how to replace Hotpoint tumble dryer thermostat
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
1helpful
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Hotpoint electric dryer model nvl333eb4cc not dryer clothes. where and how to check for the heating elements or any component that might be at fault
1. Reset a circuit breaker
2. To check the component you have to lift the top of the dryer.
3. all heating component located on the back of the drum.
4. The problem could be one of the safety thermostats or heating element.
5. To replace a heating element is to complicated if you do not have experience.
6. let me know if you going to do this
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
1helpful
2answers
Hotpoint CTD 40
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Oct 08, 2008 • Dryers
2answers
Not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
