We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to RepairNeed help fixing your appliancesNeed help fixing your appliances
all vtd range have bearing problems
hi try pushing drum at the top at the back if it lifts and nocks at all its the rear bearing cover on bake held by 2 screws you will see a pin through the shaft remove this lever bearing out to replace take lid off put bearing on shaft lift drum by rear edge so you can seat bearing
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Tumble Dryer Belts Archives How to Repair Home Appliances
sounds like you may have a timer with the contacts sticking closed at certian intervals. or a bad pcb check visual inspection of PCB look for burns or bulges, on the diodes or capcitors, Ihave in the past taken timers apart and fixed sticking contacts by sanding with emery cloth.
