SOURCE: Sustain pedal not working on my Yamaha P-90
What I figured out is that when i turn on the keyboard, if i hold down the pedal by accident, it will work in reverse. I dont know if this is what you mean. If it is, just dont touch the pedal when you turn it on. If it isn't, try to return the pedal. I dropped one, it had this problem, and they gave me a new one. Your cord for it might have been bent (?). Also, turn the keyboard on with the pedal already plugged in. It's not made to be plugged in while it's on. Hope this helps. - Matthew
SOURCE: yamaha tw200 service manual
here's one from ADV rider:
http://www.advrider.com/forums/showthread.php?t=325164
and ads somewhere:
http://www.tradebit.com/filedetail.php/6421300-yamaha-01-09-trailway-tw200-service-manual-pdf
SOURCE: ctk-601 sustain pedal issue. I am trying to use a
If the pedal is a simple switch, and not a MIDI device, then most probably the only difference is that in one pedal the switch is wired so it is normally open, and in the other normally closed.
Modifying that would involve disassembling the pedal and looking if the switch can be rewired the opposite way.
SOURCE: bought a sustain foot pedal and it works the opposite
Yep!!! Happens all the time and only a few synths have the option of selecting the operating mode.
NOW if you can open the pedal, USUALLY the switch has both the Normally Open and Normally Closed functions that a single wire can be moved to reverse the operation.
USUALLY you will need a soldering iron to make the change.
SOURCE: everytime i get inline in myyearbook it says Service Temporarily Unavailable
HELP PLS??
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
