Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Heavy Frost on the CoilsThis is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just
a little help from their friends. The problem will either be the
defrost timer (or
Adaptive Defrost Control board, if so equipped), the
defrost thermostat, or the
defrost heater. To locate these parts in your fridge, check out these cool,
interactive parts diagrams.
Just click below for more information;
There are 44 'Do-It-Yourselfer' stories about installing this part
Hope this may help you;
Regards,
VOTIT
