Televison & Video Logo
D
Dan DeGroot Posted on Oct 10, 2018
Vizio e500i-b1 turns on with logo then backlight goes out. Already replaced power board and mainboard. It will work if it is unplugged and " Cools Down for a while ". Any way to fix this?
Vizio e500i-b1 Replaced power board and mainboard
dassault1
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 20 Answers
  • Posted on Oct 10, 2018
dassault1
Contributor
Level 1:
Welcome Back:
Answers
20
Questions
Helped
3972
Points
49
Hi there, can you explain why you replaced the mainboard and psu ?
5 Related Answers
Anonymous
  • 29 Answers
  • Posted on Aug 20, 2011
SOURCE: Vizio VX37L HDTV10A no picture
Hi.
You need change the Main board. You have a micropros. problem.
zanepauldba
Zane Paul
  • Posted on Nov 13, 2014
SOURCE: i have a vizio razor led m470vt. power light flashes dim to bright. no screen but have 120v into board. replaced power board but did not fix????
I have this same problem with my Vizio. Model E601i-A3
60" LED, believe. Maybe 64"
Anyway, the solution is much simpler than these other answers make it sound. 1) Unplug tv from wall.
2) Unplug all external devices (all HDMI ports, any cable hookups, any rgb/vga connections, and any speakers attached.)
3) Unplug USB drives/attachments.
4) Plug TV back into outlet.
It should power up just fine. Then you can go ahead and reattach all your devices WITH THE TV SCREEN ON, reattach your USB sticks and you should be good to go.
Every time the TV is moved or is unplugged for any period of time, follow these procedures. The real culprit is the USB drives - the TV, like many laptops I've had, can't boot up with them attached. Thankfully once the TV learns what they are they no longer have to be removed.
richie46
  • 12962 Answers
  • Posted on Nov 13, 2015
SOURCE: Vizio tv sv420m need help
Sure that the other boards you used were any good? If so, then try the Power supply board since the other boards of your set other than the main board specialize in the video aspects. Since you have no audio the only two boards that could account for no audio are the main board and the PS board which powers everything in the set.
Testimonial: "I appreciate you taking the time to answer."
Al Kizina
  • 170 Answers
  • Posted on Jan 03, 2016
SOURCE: My Vizio E500i-B1 won't turn on, replaced the power board, still won't turn on. 24V pins are only putting out 15V, PS-On is outting out .3V. What can I check next? Please help! Thanks!
Disconnect all the circuit boards from the power supply board and test the voltages again. If the voltages are correct, connect the other boards one at a time to see if one is dropping the voltage on the power supply. If you find one that lowers the power supply voltages to what you read before, that may be the problem board.
gopakumarg43
  • 76851 Answers
  • Posted on Jan 25, 2016
SOURCE: Vizio E500i-B1 won't power on unless power is cycled. After unplugging/plugging it back in it will work but it may need the power cycled a couple of times to get the audio and remote to work reliably.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
1helpful
Vizio E601i-A3 - Logo will show then go dim?!
It could be the main, or power supply board, or the LED backlights or if your set has it the backlight inverter board but I believe on this model it's part of the power board. 1st thing I'd check is the signal from the main telling the backlight inverter to turn on, you should see a pin marked Bl_On measure there to frame ground and see if you have around 3 volts with the set on. If you don't replace the main, if you do and I think you will it's either the backlight strips or the power board that's bad, if I was going to bet I'd say it's the backlights as they fail quite often on edge lit sets as yours is according to the model number
1helpful
Vizio E500i-b1 went dark, any ideas on what to check next?
You can change boards in your TV all day and it's most likely no going to fix this set. Have you ever had a set of miniature Christmas lights that seemed to work great then all a sudden none would light, either because a bulb burned out or fell out? There are 2 types of electrical circuit wirings, one is series the other parallel. In series like your LED backlights are wired in your TV there are about 8 button lamps per circuit that have a 24 volt DC supply serving each set as this TV has what's called local dimming, one of the lamps has opened up making that set not light up, the power supply has over voltage and over current protection for each supply if one lamp opens up they all go out and this is exactly what's happened in your TV, the power supply safety circuit is non discretional, if it detects an error it shuts down the entire backlight circuit giving you no backlights. As far as a break down on what fails 5% of the times it's the main board 5% its the power board and the other 90% of no backlight failures on this model TV comes from the backlights being bad. You can change just the one bad strip if you wish but it's advised to change them all. Good luck!
VIZIO E500i-B1 broke again a month after replacing the power board. Having similar issue
You might want to check the VIZIO website for help. Given how cheap even 4K UHD TV's are today, probably not worth fixing again. Unless under warranty, of course.
I have a Vizio TV E500i-B1 and the screen is black when powered on. I have sound and able to see images with a flashlight. what do I need to do to fix it?
You have lost your backlights, look at the inverter board if its a LCD or with LED the power supply that supplies the voltage for the lamps
I have a Vizio E500i-B1, SN# LTYWPLEQ2350571, backlights and sound are OK, no picture. Ordered a T-Con board and just installed it, still no picture. Any suggestions on next steps?
you have wasted money on an experimental fix
take it in and get the problem properly diagnosed and then replace the diagnosed faulty part
Turns on, get the Vizio logo for a second then why does it go black?
My Vizio e500i-b1 LEDtv went out last night. How can i tell if it's the main board or the tcon board that isn't functioning?
I would verify the voltages on the power supply board first because an improper voltage to a circuit board may make that board look bad.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
