20 Most Recent Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Questions & Answers
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Vizio E500i-B1... | Answered on Oct 18, 2018
I would verify the voltages on the power supply board first because an improper voltage to a circuit board may make that board look bad.
Vizio E500i-B1... | Answered on Aug 29, 2018
This kind of problem is not fixable, you need a new LCD panel.
Vizio E500i-B1... | Answered on Jan 15, 2018
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Vizio E500i-B1... | Answered on Jan 24, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Vizio E500i-B1... | Answered on Oct 15, 2016
If you wish to get some details; check the site linked here. Pull up older posts.
Vizio E500i-B1... | Answered on Jul 25, 2016
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Vizio E500i-B1... | Answered on May 29, 2016
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Vizio E500i-B1... | Answered on May 14, 2016
Vizio E500i-B1... | Answered on Jan 25, 2016
Hello Michael, for what you are saying, it is very possible that the rear lighting of the LCD panel is not working, usually two or three LEDs are burned, these come mounted in strips
To make a good repair, you have to change all the LEDs or replace all the LED strips
I give you the link of a video of another Vizio TV model, which shows you how to replace the LED strips
I hope you can solve the problem
Greetings Franco Dosil
Hola Michael, por lo que comentas, es muy posible que no esta funcionan la iluminaci?n trasera del panel LCD, por lo general se queman dos o tres LED, estos vienen montados en tiras
Para hacer una buena reparaci?n, hay que cambiar la totalidad de los LED o sea reemplazar todas las tiras de LED
Te paso el link de un v?deo de otro modelo de TV Vizio, que te muestra como reemplazar las tiras de LED
Espero que puedas resolver el problema
Saludos Franco Dosil
Vizio Televison... | Answered 2 days ago
Check that you have selected the coorect source. Av , TV , HDMI etc.
It could be many things but i would start with the power supply board with the power problem, could just be bad capacitors, which is so common on tv and monitor power supplies.
However, the colored lines could be an even worse sign that the mainboard failed if the power supply output voltages are good.
I would start with checking the voltages from the power supply board, if your lucky the voltages are labeled at one of the connectors. If all the voltages are what they should be, and you don't see any bulged capacitors, then its most likely a failed mainboard. Not much you can do to repair them, just have to find a replacement, which in itself can be difficult!
Vizio Televison... | Answered 3 days ago
Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
16 questions posted
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
vizio model e500i b1 serial
  • Televison & Video
