Watches Logo
Cathy Pratt Posted on Oct 09, 2018
When we are watching stuff on etf,I it keeps going back to home about every 5 minutes or so. Can you help fix this?
1 Related Answer
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 08, 2010
SOURCE: my watch back 5 minutes in an hour
The first thing to do is to replace the battery. If after battery replacement your watch still loosing time - there is a technical/mechanical or micro-electrical problem and you will have to look for professional watchmakers help.
Rate me, plz.
Ac/lb light keeps flashing and home alarm beeps every 5 minutes or so and i cant get the light to go off
What model is your alarm system? The maker (Honeywell, Ademco, DSC, Napco, Caddx, ITI, GE, Moose, Morse, etc etc etc) and model number is usually inside the door of the control panel cabinet on a diagram. Numbers printed at the top of the control panel (NOT the keypad) circuit board is also helpful.
1helpful
Stauer watch will not work after battery change.
I have no ideal how old your watch is nor where you had the battery changed. Ideally I would take back to whom changed the battery to see if it was a good battery. If your watch is older it may be time for an adjustment.
Contace Stauer for further assistance at link following:
http://www.stauer.com/customer_service.asp
Good luck.
1helpful
My watch back 5 minutes in an hour
Rate me, plz.
3helpful
2answers
The anlog display does not synchronise with the digital display.There is a time difference of 2.5 hours. I got the batterie replaced which didn't change anything.Thank you in advance for your help
Activate the crystal, then find the clock calendar function. Hold the center button for 5 seconds until a synchro appears on the data screen, then start pushing top button to move the minute hand to the 12:00 then push bottom button to move minute hand to 12:00. after this is done hold center button for 5 seconds and hans will move to match time on your digital display. Now that you are synched,you can set time as you normally would.
JRH, Rhode Island
7helpful
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 • Watches
6helpful
2answers
Casio 4305 runs 5 minutes slow.
No reason to panic as your watch hands can be advanced to desired time. Her is the link for your watch users manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4305&submit.x=52&submit.y=12
Save it on your PC and follow instructions how to set the time.
Don't forget to rate, please.
Jan 05, 2009 • Watches
Cant get Casio 4303 to enter receive mode
See: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf
and go to the section "Adjusting the Home Position"
This is a "calibration" procedure to get the motor of the analog movement back to the home position of 12:00. This worked for me, after replacing the battery.
Note that in this procedure the hour hand does not move separately, but moves with the minute hand. So to get the hour hand to move, you have to let the minute hand spin a number of times until you get the hour hand up to twelve o'clock.
58helpful
7answers
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Top Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Watch Expert? Answer questions, earn points and help others
