The Kenwood KR-V8070 has no digital audio inputs; it only has analog inputs. You can see the manual's diagram of the rear input/outputs starting on page 4 at ManualsLib: https://www.manualslib.com/manual/287040/Kenwood-Kr-V8070.html?page=4#manual . If you need to connect a device that doesn't have an analog audio output, you will need an analog to digital audio converter. This is one version: https://www.amazon.com/SANOXY-Analog-Digital-Converter-Adapter/dp/B005F20756 . You will need to supply all of the audio cables separately.
The later KRF-V8070D does have coaxial and optical digital audio inputs. I hope this helps.
SOURCE: no dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
SOURCE: no signal when hooked up with a digital cable box
I had the same problem and had the cable guy out and everything thinking it was my box. I figured it out by myself here is what i did to fix it. I have the vizio 32 inch hooked to an hdmi cable and through the cable box i had the aspect ratio on 1080i and i should have had it on 720p once I switched it I havent had the problem since.
SOURCE: I have a new Samsung 47 in LCD and Kenwood DVD
Without additional equipment it can't be done. As i see your VR-606 pure analog device, and you trying to somehow use 5.1 sound from HD STB that is on HDMI put on RCA connectors of your VR-606. It is impossible without converter from HDMI to Analog audio or something likethis, best way to buy new receiver with HDMI input and TV neither Receiver with HDMI out oportunity. Then you will have your home cinema. In your current setup probably you can play only with stereo from your stb.
SOURCE: Hooked my L32HD35D to a digital cable box. TV
Try it with the HDMI cable.The RCA component cable some time it don't work.
SOURCE: Kenwood KR-V8070 has power but audio quit working.
Can you hear the speaker relays clicking on ? unit might be in part protection
