I didn't use it for a long time and i just reinstall it on a windows XP. By the status monitor i can adjust 5mm but what to do when it's more? Thanks for reply
SOURCE: Rimage Everest
Rimage has made alot improvements with their latest Everest 600 printer when it comes to color density and accuracy (the Everest II is now 2 genereations old).
www.techwaredist.com
SOURCE: Epson r260 status monitor wont show up
Try these steps ::>>
Go to Control Panel / Printer and Fax and then right click on the
R260 printer icon / from the options left click on printing preferences /
on the Printing Preferences window click on Maintenance Tab / on the
lower right click on the Speed and Progress Tab / on the Speed and Progress window there are check boxes look and see if the box for the Disable EPSON Status Monitor 3 has a check on it ( if it has a check., remove it )
SOURCE: hi ,our rimage perfect image sometimes
Most likely the sensor cable is bad. I have them is stock for this printer.
John Norman
Max Optical LLC.
[email protected]
610-269-7033
SOURCE: why does my printer takes ages to print a disc
The printer will take about 5 min to print the first disc as it needs to warm up and then every disc after will take 60 ~ 90 seconds depending on the quality settings.
John Norman
Max Optical LLC.
[email protected]
610-269-7033
SOURCE: Rimage Everest ii Tray won't
Hello Chris_sizer,
Open the side of the printer that holds the ribbons.
Remove both the CMY and the Retransfer Ribbon.
There is a metal plate under where the CMY ribbon goes in that has 3 screws, two are located tward the front and one is located on the back wall on a metal tab.
Remove these three screws and the plate.
Now you can remove any debris or discs that are blocking the tray movement.
If you need more assistance, please give our support team a call at 1-800-553-8312 (Option 2)
