20 Most Recent Rimage Everest II Printer Questions & Answers
Our Rimage Everest II doens't print anymore. It produces only white DVD's. You can hear that the machine is doing something but there is neither a print on the CMY-Sheet nor on the ReTransfer-
Most likely the printhead is bad and needs replacing. John Norman Max Optical llc. www.maxoptical.com
6/16/2014 2:04:41 PM • Rimage Everest... • Answered on Jun 16, 2014
Replacing the hallogen lamp of the rimage everest
Replacing the hallogen lamp is a big job. Usually it is adviseable to purchase a refurbished printer at less cost. I can help you with either solution. John Norman Max Optical llc. www.maxoptical.com
6/16/2014 1:50:06 PM • Rimage Everest... • Answered on Jun 16, 2014
Rimage Everest II printer can't be adjusted
Usually this is caused by the black index marks on the transfer roll not being indexed properly. Look at the used transfer rolls and you will see small black lines that the printer used to index the print. Either they will not be crisply printed on the transfer pointing to a bad ribbon, bad or dirty printhead. OR, the sensors are dirty that read this index mark. John Norman Max Optical llc. www.maxoptical.com
6/16/2014 1:48:38 PM • Rimage Everest... • Answered on Jun 16, 2014
Everest ii printhead lever out of position how do you resolve this issue
Blue lever inside the access door. The lever that allows you to remove the ribbon carrier. John Norman Max Optical www.maxoptical.com
6/16/2014 1:43:55 PM • Rimage Everest... • Answered on Jun 16, 2014
2answers
Lost my installation disk for rimage everest 2 how do i install it now??
Looks like these devices are at end of service life, you might try contacting the manufacturer for the software. Try this link to their website and contact information. http://www.rimage.com/support/end-of-service.html North America 866-587-5903
4/8/2014 8:20:17 PM • Rimage Everest... • Answered on Apr 08, 2014
0answers
0answers
Rimage everest 2 prints get darker after 10 prints
1. for print cartridge2.for print media3.for room temperature not adjust with printer needed .4bad contact with print cartridge and the printer
12/8/2013 3:37:56 AM • Rimage Everest... • Answered on Dec 08, 2013
0answers
How to clean the print head
No easy way to clean the print head. You will need to remove it from the printer to gain access to the area to clean. What does the label look like on the disc? Streaks is probably a dirty print head. If sections of the label are missing it could be the print head or heat roller. Look at the re-transfer (clear) ribbon. If the missing part of the label is left on the ribbon you have a heat roller issue.
7/17/2013 4:52:51 AM • Rimage Everest... • Answered on Jul 17, 2013
How to calibrate printing area?
If you're seeing an off center label that appears as a crescent you can use the print properties status monitor to align the label.
7/17/2013 4:42:41 AM • Rimage Everest... • Answered on Jul 17, 2013
2answers
The encoder for drawer motor
Double check to make sure the shipping screw has been removed.
7/17/2013 4:22:06 AM • Rimage Everest... • Answered on Jul 17, 2013
I need a printer driver
- go to this link and download the latest driver
- http://www.rimage.com/support/printer-serieverst-ii/152.html
7/2/2013 4:05:47 PM • Rimage Everest... • Answered on Jul 02, 2013
Rimage Everest II Printer Logo
53 questions posted
Top Rimage Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Rimage Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Rimage Office Equipment & Supplies
Most Popular Question
rimage everest 2 prints get darker after
  • Office Equipment & Supplies
