What good is start up repair? Microsoft is forcing the user to re=install the operating system....
SOURCE: Gateway M305CRV
Hi, you still need to do the updates before you can put software on. On the desktop go to START....ALL PROGRAMS....then at the top you will see an item marked UPDATES. Click and go from there, it will download a lot of items as long as you are connected to the internet.
STP162
SOURCE: My DELL Laptop can't install XP, Vista, Linux
i think i know what yr saying. if u installed the xp into yr hard disk from a diff system then brings it back to yr system it possibly will not work cos these board were not made of the same chips. i dont think yr motherboeard is bad i think yu have just done the wrong thing.
if yu can tell me yr problem in details i will tell u what to do.
thank u
SOURCE: Windows Vista Installer corrupted/freezing
if you are sure that there is some problem in windows installer then you can download the windows installer from the following site and try installing it ....
http://www.microsoft.com/downloads/details.aspx?familyid=5A58B56F-60B6-4412-95B9-54D056D6F9F4&displaylang=en
and if you couldnt able to install in the normal mode then just go safe mode and try installing the windows installer ....
then the problem will surely be solved
you can go to the safe mode by pressing F8 at the time of the system boot ....
after pressing F8 you must choose the safe mode ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
SOURCE: hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
You can not dual boot with oem software from HP. I run dual boot linux and XP. I tried everything to get vista to work in the dual boot. Here are your options.
Get a full copy of windows vista and XP with keys. Windows vista can not be the HP Cd for reinsatlation of windows. It has to be a stand alone copy of Vista. Back up data. Format drive, install xp, install vista.
Option 2 see it there is to uyse a virtualization software I use Kubuntu (Linux) with virtualbox and I used the HP disk to instll in the virtual machine. It is not a perfect system but it allows me to work on vista, and xp while never having to dualboot. think of it as windows in windows. or I like windows in Linux.
http://www.virtualbox.org/wiki/Downloads
Is the download page for virtual box.. let me know if you need more help.
SOURCE: Cannot change operating system on Gateway GM5478?
Make sure you have enough hard drive space. Also make sure you have enough RAM to support the Operating System
