20 Most Recent
Microsoft Windows Server 2003 Standard Edition with SP1 for PC Questions & Answers
I want to break the password of windows server
I think the best way for you is using shareware like windows password key if you have
lost windows password.I've tried a couple of these utilities through the years and my favorite is the
windows password key .This utility is used to reset password of any windows versions in seconds.
1. Login to a computer that can link to Internet. Download
windows Password key and install it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD or a USB flash drive.
2. Insert the newly created CD/USB drive to the locked computer.
3. Reboot the locked computer and press'F2'or'Delete'to enter your BIOS setup and then followed the process of instructions. Just a few steps, the old password was removed.
4/6/2016 8:02:02 AM •
Microsoft...
Answered
on Apr 06, 2016
Why does windows Server 2012 has no support for
Windows Server 2012 to have no support for Itanium-based computers. Oracle/Sun were sued by HP because Oracle has stopped releasing software for Itanium. Now that Microsoft has stopped supporting Itanium for future software does that mean HP or Intel will try to sue Microsoft ? --
tygrus (
talk) 03:43, 24 May 2012 (UTC) isinya kamseupay :p - Preceding
unsigned comment added by
175.111.116.66 (
talk) 08:26, 23 August 2012 (UTC)Chances of you seeing this are slim, but I'll reply anyway. No, it doesn't. The basis of HP filing against Oracle was that when an exec left HP to work for Oracle there was an agreement that Oracle would continue supporting the Itanium architecture HP was happily turning a profit off. When Oracle announced they were dropping the dead donkey HP sensed a massive impending loss of revenue and filed suit to force Oracle to prop up what is basically a failing business model. Intel only support Itanium because HP has paid them quite a chunk of money to do so. At this point I don't think Microsoft has any investment in either direction, but each release requires porting to be done and the m
10/16/2013 12:08:42 PM •
Microsoft...
Answered
on Oct 16, 2013
I want to install a mixer device
Sound options are disabled for Windows server 2003. You have to enable sound and audio services using the "Services" panel. You can install that and then Enable the services.
After installing click on Start - > Run -> Type in services.msc and hit enter key.
Then scroll the list and find the related Service. Right click on it and go to Properties. Then select "Enable". Set the Startup mode to "Automatic".
7/21/2010 4:08:58 PM •
Microsoft...
Answered
on Jul 21, 2010
Bloking internet connectivity
You can setup the two switches to be on two different VLANs if they are smart switches and assign the IP's to the sepearte networks via DHCP. you can then block internet for the desired IP range and allow for the other subnet,
6/8/2010 1:11:17 AM •
Microsoft...
Answered
on Jun 08, 2010
BDC for Windows Server 2003
Windows 2003 does not use the PDC/BDC format like the old NT did. They are all just considered DC's now.
Just run dcpromo on the new domain controler and select the option "additional dc to an existing domain". Once that is done, if you are using Active Directory, it will sync up with the other DC.
1/23/2010 2:44:20 PM •
Microsoft...
Answered
on Jan 23, 2010
His copy of Windows must be activated with
I would guess that a complete rebuild was done on this system using the product key that came with the box. In order for this software to work properly, you must activate the key. This is done at the factory before the unit is shipped and when a complete rebuild is done, you must perform this step as well. Connect to the internet Microsoft website to do this. If you do not have an internet connection available, there is the option to perform the activation over the phone. Once this information is entered, the system will be fully functional. This must be done to verify and validate the OS installation.
Dan
6/9/2009 1:32:12 PM •
Microsoft...
Answered
on Jun 09, 2009
Tally support
maybe the licence for tally 9 is stored in an area of an application server on the network you dont have security access to? Do you have a system admin onsite to check this for you?
1/11/2009 5:24:27 PM •
Microsoft...
Answered
on Jan 11, 2009
