SOURCE: Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
SOURCE: kitchenaid compressor starts then hear a click and it stops
most likely you have a bad start relay on the compressor. when looking at comp on the left side you will see a little square relay with 2-3 wires going to it. the pt# you need is 8201786 and can be purhased online or at a local appliance parts house this is an easy repair and the part should cost you less than 70 dollars. thx peyton
SOURCE: 2002 Mitsubishi Montero Sport XLS transfer case issue.
The best place for a DIY manual is www.ALLDATADIY.com their info is very accurate.
SOURCE: Gringing noise when printer boots up and when it prints
Probably worn gears for the rollers along the paper path or the gears that mesh with the imaging roller in the toner cartridge. Remove the toner cartridge and reseat it. Also look for any rounding of the gear teeth on any of the rollers while you have to cartridge out.
SOURCE: Stops after a few feet
It can be in the power supply or the motor pack. You can contact us using the dolphin service form at www.arrowpools.net or try the manufacturer at www.maytronicsus.com.
