20 Most Recent Troy -Bilt String Trimmer/Blower Attachment #41AJBT-C966 Questions & Answers
Troy bilt pole saw will not lubricate any more
I assume you are talking about the oiler for the chain and if so it sounds as if the oiler is either blocked with chips or it is broke. You can go to ereplacementparts.com and put the model and model number in and it will show a drawing of the saw and you can then fix the problem.
10/20/2016 1:24:27 AM • Troy -Bilt... • Answered on Oct 20, 2016
What causes the trimmer head to stop turning when it starts cutting heavy grass?
Check out the drive unit from the head of the motor down to the trimmer head it may have a problem.
10/20/2016 12:56:58 AM • Troy -Bilt... • Answered on Oct 20, 2016
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
10/20/2016 12:42:12 AM • Troy -Bilt... • Answered on Oct 20, 2016
2answers
The primer bulb on this string trimmer wont
When the primer bulb sticks down either the cause can be
1. Fuel line is clogged
2. Fuel shut off is in the OFF position (if installed)
3. Fuel tank pick up tube is folded over or clogged. (inside the fuel tank)
I checked this model number: 41AJBT-C966 and it did not cross exactly. I found several C966 diagrams but they all have different engines from 25cc all the way to 65cc. If you need more help it will help me help you if you know your engine model number (i.e TB25 TB42 etc.) and would post it in your response.
Thanks for using FixYa.
Kelly
4/20/2014 3:55:07 AM • Troy -Bilt... • Answered on Apr 20, 2014
Do I have to line up piston rings a specific way
yes make sure the open ends do not line up, stagger them in 3rd's oil well before you put the piston in the ring compressor. Make sure you have the piston "Front mark" orientated properly before instalation.
10/9/2013 6:51:26 PM • Troy -Bilt... • Answered on Oct 09, 2013
2answers
I have a cracked fuel tank which I tried to fix
No shouldn't affect that. Try using a mixture of super glue and baking soda smear it on and press into crack I have had good luck with this when many commercial products failed.
1/19/2013 8:33:00 AM • Troy -Bilt... • Answered on Jan 19, 2013
Troy Bilt in Hell String Trimmer TB465SS Running Problem
You need to clean the carb. or you may need to buy a carb. kit. But do a cleaning on it first. If you need tips on how to best do this, just let me know. Also check the fuel lines for cracks. As they age, they become brittle.
Jim
10/19/2012 4:52:58 PM • Troy -Bilt... • Answered on Oct 19, 2012
Need to replace primer bulb,
The primer bulb can be replaced without replacing the whole assembly. If you have any questions on how to do this let me know.
8/4/2011 10:48:25 PM • Troy -Bilt... • Answered on Aug 04, 2011
String flys out when engine
It sounds like you are winding the line in the wrong direction. You should wind the line in the opposite direction that the head spins during operation.
Good Luck!
Jim
7/31/2011 5:19:02 AM • Troy -Bilt... • Answered on Jul 31, 2011
I have a tb-465ss and wanted to know if I can just
You can replace just the bulb...
8/14/2010 3:58:24 AM • Troy -Bilt... • Answered on Aug 14, 2010
I have a troy bilt
hello,you can kindly download your troy bilt manual from the link below and also instruction on how to use it.
lawnandgarden.manualsonline.com/manuals/.../troybilt/tb70ss.html -
lawnandgarden.manualsonline.com/ex/thread/view/.../2153537 -
wish you good luck,
take care.
5/13/2010 7:53:49 PM • Troy -Bilt... • Answered on May 13, 2010
Troy-Bilt weed eater, Model TB90BC, had rotten
Prime and watch the fuel move up to the carb. This is the fuel line and it should be long. Make sure it goes to the bottom of the fuel tank.
5/7/2010 7:05:51 PM • Troy -Bilt... • Answered on May 07, 2010
2answers
Troybilt TB75SS String Trimmer will only run choked
It sounds like your carburetor needs a good cleaning. You must disassemble the carb., clean all the ports with a small Den Tech Brush, (used for cleaning between teeth). They are very small and perfect for this job. You will also want to clean the small screen in the carb. It may be so clogged that it may need to be replaced. If this is the case, you will need a carb.kit for your Troybilt Trimmer; it comes with small parts and gaskets. (It will come with some gaskets that you will not need.) Replace all old parts with the new ones. This should fix your problem.
5/3/2010 1:31:11 AM • Troy -Bilt... • Answered on May 03, 2010
I can start it, but it shuts down after a 10
The model number for your post is for the blower attachment. Can you pass the model number of the upper assembly please so we can better help you. Thanks
Kelly (cont below)
I am going to go out on a limb here.. Most of these troy-built trimmers use this carb with primer bulb.
PN 753-1225
http://www.ereplacementparts.com/carburetor-with-primer-p-283336.html
What usually happens to them is the primer bulb on the bottom of the carb gets a pin-hole in it and then air is drawn into the carb vs fuel from the tank.
You can try to get just a primer bulb at your local lawn mower parts supply. You may just have to bite the bullet and replace the whole carb.
4/19/2010 12:47:16 PM • Troy -Bilt... • Answered on Apr 19, 2010
I have a TB465ss weed eater. It was running fine
Sounds like you have fuel leaked into the cylinder. Remove the spark plug, empty it out, pull the rope a few times to force out the excess fuel, dry the plug off and put it back in. Don't put the choke on, open the throttle all the way up, and she should start. Remember, liquid doesn't compress, and sometimes changes in temperature or atmospheric pressure can push fuel through the system and into the cylinder.
3/24/2010 9:05:54 PM • Troy -Bilt... • Answered on Mar 24, 2010
Troy -Bilt String Trimmer/Blower Attachment #41AJBT-C966 Logo
35 questions posted
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
View Most Popular
Troy Garden
  • Troy Garden
Most Popular Question
engine flooding out stalling full
  • Garden
