20 Most Recent Troy Bilt 175HP Manual 42" Riding Mower Questions & Answers
If you didn't put fuel stabilizer in gas before letting the mower setup all winter, your gas has gunked up your carb.
You can verify this by removing the air filter and spraying starter fluid in the carb. If it cranks with the starter fluid, the carb is dirty.
Pull the carb and clean it out
Troy Bilt 175HP... | Answered on Dec 08, 2017
carb floats have been known to stick . but if it back fired then it could have sheared the flywheel key .best to check crankcase also for gas . trying to run it will destroy it totally
Troy Bilt 175HP... | Answered on Sep 12, 2017
Your owner's manual indicates to change the oil and replace the oil fitler on page 19 as part of the regular maintenance schedule. Whether or not your exact engine application does indeed have the filter is the engine manufacturer's option. Here is your manual.
http://www.troybilt.com/wcpics/TroyBiltUS/en_US/wwcm/769-03502.pdf
Troy Bilt 175HP... | Answered on Sep 01, 2016
Normally this caused by a leaky float needle valve in the carburetor; although, if you have a vacuum operated fuel pump it internal may ruptured.
Troy Bilt 175HP... | Answered on Apr 13, 2016
Might be a full tank of wet gas from over-winter condensation.
Troy Bilt 175HP... | Answered on Apr 11, 2016
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
look for a wire with a bare spot the is rubbing on metal
Troy Bilt 175HP... | Answered on Oct 15, 2015
Try Goggle it. belt diagram troy -----
Troy Bilt 175HP... | Answered on Oct 13, 2015
This sounds like your Deck Belt drive has come off or has stretched & needs replacement.
This is normal wear & tear, easy to look for under the machine, you may be able to slip it back, on see this site for full descriptions.
http://www.troybiltpartsonline.com/oemparts. Hope this helps you. Best Wishes. Malcolm.
Troy Bilt 175HP... | Answered on Jul 04, 2015
Belts dont move mower back and forth, there is a bar that engage the hidrolic transfer, perhaps you move it and you have not tracking power, or, there are a series of rods that actuate the hidrolic, coud be that any of those rods came undone, if any of these to scenarios is happening to you, consider have the hidrolics chec out.
Good luck to you.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Troy Bilt 175HP... | Answered on Jun 29, 2015
Those belts do not tighten you will have to replace it,sorry.
Troy Bilt 175HP... | Answered on Jun 26, 2015
Check your battery and see if its fully charged. I had a battery that the charger said was fully charged but a cell was dead. Take it to a battery store and they will check it free of charge.
If that's not the problem check all the battery cables on both ends for being tight and clean. If that's not the problem you could have a bad starter.
Troy Bilt 175HP... | Answered on Jun 08, 2015
Didn't take long to find this belt. Check out this link:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=pto+belt+742-0485
Troy Bilt 175HP... | Answered on Apr 26, 2015
Sounds like you have an issue with a broken or off pulley belt.
Troy Bilt 175HP... | Answered on Mar 03, 2015
THE FUEL PUMP SHOULD BE ON THE SIDE OF THE MOTOR. THERE IS THREE HOSES THAT WILL HAVE TO BE UNHOOK TO PLACE THE NEW PUMP INTO PLACE BE SURE TO HOOK THE SAME WAY THAT YOU TAKE THE OD ONE OFF
Troy Bilt 175HP... | Answered on Mar 01, 2015
there is a safety switch that may be out of adjustment when you engage the deck
Troy Bilt 175HP... | Answered on Feb 28, 2015
Troy Bilt 175HP Manual 42" Riding Mower Logo
323 questions posted
Top Troy Garden Experts
Neil Hancock
Jay Finke
Jay Finke
lnbn1975
Are you a Troy Garden Expert? Answer questions, earn points and help others
View Most Popular
Troy Garden
  • Troy Garden
Most Popular Question
gas keeps getting in oil wrong
  • Garden
