Start on page 17. this should be done by electrician. pump is 230 vac and there must b a different wiring to use 120 vac. Call an electrician, and stop replacing igniters.
https://www.jandy.com/~/media/zodiac/global/downloads/h/h0248900.pdf
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
SOURCE: I have a Jandy Lite 2 Heater model LG250N
You don't use heater very often. make sure you clean gas nipplets from web, wasp nests try that?
SOURCE: Jandy Lite 2 LG Model not firing up. Was working during day
ok 24 v at the transformer is yes than a safety swicth turn the heater off check fuses
SOURCE: Jandy Lite 2 LJ will not ignite
water is leaking down onto the burner putting out the heater????
SOURCE: Solution for Jandy Lite 2 Pool Heater display flashes on & Off ..
Can a model LJ250P Propane 2005 model be installed indoors . The rating plate says it can. But manual says it cannot. What the hell????
Igniter circuit is open. Check fuses on igniter wires. Identify and correct loose or broken wires.
Element has a fine crack in it. Replace
Igniter fault. Replace igniter.
