20 Most Recent Jandy Lite 2 Natural Gas Pilot Light Heater Questions & Answers
2answers
How do I fix a FL4 code
A FL-4 error is an ignitor failure. There are three things that need to be checked to correct the issue. First is the ignitor. Replace if broken or burnt or cracked. Second is the 220/120 vac conversion plug that is plugged into the main board in the burner compartment behind the box cover. The black transistor may be burnt. Replace if burnt. This will happen often if the heater is connected with 220 vac power source. I highly recommend connecting to a 120 vac source if possible. The heater seems to like it more. But remember when switching power supplies to follow all manufacturers instructions on doing so. If after replacing these two items the FL-4 problem still occurs, the control board in which the conversion plug plugs into also may need replacement. This should correct the fl4 error.
6/8/2019 2:07:48 PM • Jandy Lite 2... • Answered on Jun 08, 2019
0answers
0answers
0answers
Not lighting
Be the first to answer 4/29/2016 12:19:26 AM • Jandy Lite 2... • Posted on Apr 29, 2016Be the first to answer
0answers
0answers
0answers
Jandy xli
Be the first to answer 3/5/2016 3:25:30 AM • Jandy Lite 2... • Posted on Mar 05, 2016Be the first to answer
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
Popular Tags
172 questions posted
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
ZJ Limited
ZJ Limited
john h
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Jandy Pool & Spa
  • Jandy Pool & Spa
Most Popular Question
high limit switch jump
  • Pool & Spa
