SOURCE: kirby
If your shampoooer is laying out WET foam in the center of the tray and not all the way across, you are missing the wee round suds screen that goes over the hole where the hose attaches to the tank. It may be wedged in your hose. If the foam is white, bubbly and stretches from one edge of the tray to the other, you may not have the belt connected to make the brush spin, or you may not have the height adjustment on it's lowest setting.
SOURCE: Kirby Sentria - Not distributing shampoo correctly
this site may be helpful
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting. Also...shampoo at a slower pace than you would move when vacuuming...when both putting down the suds on heavily soiled areas and scooping them up. The more oils in the carpet, the less suds you'll see when the shampooer is working properly.
one more thing that may be mentioned in the guide is the little round sud screen that attaches to one end of the shampooer hose...make sure that little mesh screen is there and seated properly. It is what produces the suds from the shampoo solution.
SOURCE: kirby shampoo instructions how to assemble shampooer
This is also a great place to order Kirby supplies!
SOURCE: carpet shampoo system
I KNOW THIS IS AN OLD POST BUT MANY PEOPLE MIGHT STILL FIND THESE ANSWERS USEFUL. I CAN ATTEST TO THE FACT THAT YOU NEED TO USE THE KIRBY SHAMPOO. I TRIED TO SAVE MONEY AND USE OTHER BRANDS BUT IT NEVER WORKED AND WOULD DISPENSE MOSTLY LIQUID INSTEAD OF FOAM. IF YOU USE THE KIRBY BRAND, YOUR SHAMPOO SHOULD FOAM AS IT IS DISPENSED. GO SLOWLY AS THE PREVIOUS RESPONSE SUGGESTS. ANOTHER THING... I WOULD SUGGEST RAISING THE HEIGHT A LITTLE SO THAT IT IS NOT TOO CLOSE TO THE FLOOR.
SOURCE: dont know how to put the shampoo system together on my kirby g6..
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
