You can fill it up to 1/4 of an inch to the top/cap, do not overfill. You can use 5w30, 10w30 or SAE30wt oil depending on the ambient temperature. In ambient temperatures of 55-above SAE30 wt is recommended. See Oil Recommendations in the image I added below. SAE 30wt oil is the normal viscosity to use in most regions unless you are going to use it in sub 0 temperatures and then you will need 5w30 or 10w30.
SOURCE: Oil stick is stuck
Have you ever checked it before? Do you know if it's a screw on cap? It could be that the cap is slotted, and is only supposed to turn a 1/4 turn. Try not to force it, and use a light touch.
Hope this helps!
C
SOURCE: I can't locate the transmission fluid dip stick for 2003 Grandam
Your transmission is sealed and has no dip stick, checking the fluid level properly involves using a factory scan tool.
SOURCE: Why is my engine oil so thin like water and has a
Sounds like fuel in oil obviously. Don't run it until you cure problem !! You may have a an injector leaking down or something. If your fuel is mixing with oil, it's just a matter of time before it seizes if you keep running it. Has it had starting problems lately?
SOURCE: oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
SOURCE: can't find dip stick to check oil on suzuki motorcycle c90t
There is no dipstick on suzuki . Stand beside your bike and look on the bottom right side of your crankcase . look for a little site glass window . That is how you
check . if the oil is half way up the glass when you stand bike straight up . . change every 3000, plus filter
