20 Most Recent
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Questions & Answers
No power on electric durabuilt 1400 pressure washer
sounds like a pressure switch is sticking. usually causes this problem especially after being stood for a while not used.
have
to remove cover to get to pressure switch, remove pressure switch
piston clean regrease with silicon grease refit it m and all should be
good.
4/10/2017 5:16:14 PM •
Coleman...
Answered
on Apr 10, 2017
Wand leaks
The wand split because it was made incorrectly.The identification number on the tube decreased the wall thickness and caused the tube to split. All the info by mr fixit is bs
4/21/2015 2:15:36 PM •
Coleman...
Answered
on Apr 21, 2015
Need replacement wand for 1400-PSI electric pressure washer
Check out your nearest Coleman dealer / ebay etc. But also look at whether the wand of another brand would fit. Most of this stuff is Chinese branded to suit the supplier and it may not be economic to buy a new wand but seek out a local / online deal on a better product like Karcher.
4/20/2015 9:49:04 PM •
Coleman...
Answered
on Apr 20, 2015
Excessive leaking on gun handle
The pressure comes from very sealed container and with the weather hot and cold usually the housing start to expand and let the pressure out…same with the hose. Fixing the unit may be more than the price for new one… If you like to try look at hardware stores, True Value, etc. for the parts…let me know
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
4/19/2015 2:10:55 PM •
Coleman...
Answered
on Apr 19, 2015
Why does the machines cct breaker trip on a simoniz S2000 XE02 pressure washer
It could trip for a number of reasons. If you turn it on and nothing happens for a few seconds or instantly trips the motor is overloaded or burned up or a motor capacitor is bad. If the machine turns on and sprays if you hold the trigger open while you turn it on and then trips when you let go of the trigger you probably have a problem with the cut off switch . The circuit breaker might be too small for the load of your machine. The extension cord might be too light duty and causing the breaker to trip.
8/21/2014 3:58:45 AM •
Coleman...
Answered
on Aug 21, 2014
Coleman Powermate pressure washer PW0872400.01
The systems are simple but if they aunt stored correctly(allowed to freeze) or the air isn't purged out of it. It can result in damage to the machine.If water is dripping out of the pump it is damaged. if not then it could be air (purge system), or a damaged or stuck check valve.
5/11/2014 4:10:03 PM •
Coleman...
Answered
on May 11, 2014
Durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
7/20/2013 12:15:38 AM •
Coleman...
Answered
on Jul 20, 2013
What is the price on one of these use
You can get parts for it but you need some odd tools to work on the pump. You will need a torque wrench, seal drivers that are a special size for the pump seals, and a good set of regular tools. You need to have a pick set for pulling the seals and the valves.
6/10/2013 1:42:00 AM •
Coleman...
Answered
on Jun 10, 2013
I can't get the pressure washer to start up. The water is coming out of the hose, but there is no water pressure
If the washer is the kind that shuts off completely when the pistol grip is released, the problem is likely the little pressure sensor located near the output fitting (the threaded part to which the hose connects). The sensor is a little plunger held down against an opening in the side of the pipe by a spring when there is low or no pressure in the output pipe, as when the trigger is pulled and the pressurized water in the hose is released by pulling the trigger. That completes the electrical circuit and the washer is on and continues pumping water. When the trigger is released, water in the hose and output pipe jams up super high pressure, forcing tjhe little plunger out against the spring, and the electrical circuit is broken. If you take the case apart, you will see wires coming from that area. The fix (if this is the problem) is to free up the little plunger.
2/9/2013 5:30:33 PM •
Coleman...
Answered
on Feb 09, 2013
