I have a 3 year old Keystone dehumidifier model KSTAD50B in which the fan does not operate and the compressor won't turn off unless the unit is unplugged. I removed the case to check the compressor and it is doing its job just fine - the coils get cold quickly.
SOURCE: Dehumidifier Compressor is not working
this unit is very simular to an air conditioner except it has a humidistat instead of a thermistat.. if your handy with a continuity tester unplug the unit find the humidistat and check to see if its open or if its good then call the company at 1 800 322 3848 or contact the web site at [email protected] Good Luck
SOURCE: no water coming out, and no cold coils
Sounds like the unit needs re-gassing and checking for leaks. It is not unusual for a 3-year old unit to require this - especially dehumidifiers as they are often not used all year round, and the seals that stop the gas from leaking are prone to settling and drying out when not in use. This is not a procedure that you are permitted to carry out yourself, just call a local HVAC/Fridge repairer and see what they quote - the job itself is simple enough depending on the leaks and if anything needs replacing, but the gas itself is getting costly. Make sure they do a leak test first. If not topped up with gas then don't run the compressor - the lubricant that protects the compressor is mixed in with the refrigerant gas and will dry out quickly if the gas has leaked. Hope this helps - please ask for more info if you need it :)
SOURCE: DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
SOURCE: Dehumidifier runs but does not condense water.
It sounds like an issue with the control bord. This dehumidifier should have a 5 year warranty through LG. You will need to have this serviced. If it is under warranty by LG they will either refer you to a local repair shop and they will pay for the repair or they will replace it if you do not have a repair shop in your area. Call them and explain the problem to them. Make sure that you have your reciept. Here is the contact information for LG:
Toll Free Phone Number: 1-800-243-0000
Email: [email protected]
Keep me posted. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
SOURCE: Frostguard 36 Dehumidifier runs, but collects no water.
unfortunately it sounds as though your refrigerant leaked out. If your compressor is running and no moisture, this is probably the case. What is the temperature of the air coming out?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
The compressor relay can be accessed by removing the terminal cover
box. The cover is held on by tension or with a retaining clip.
