20 Most Recent
Frigidaire a/c fad704dwd 70 pint dehumidifier Questions & Answers
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Why does Frigidaire dehumidifier FAD704DWD send water outside unit?
Good Afternoon Friend,
I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful.
-Best Regards-
WP
Meaning of "F1" in a Frigidaire Dehumidifier model FFAD5033R1?
For the slightly larger model, FFAD7033R1, F1 turned out to be the humidity sensor. This can be accessed by removing just the back panel.If you have a soldering iron for less than a nickel you can just replace the NTC Thermistor (small orange resistor 10k) on the small PCB. See attached image below.In the image below just to the right of the white sensor you can see I removed the bad thermistor..
How to locate and replace internal filter?? For frigidaire
I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps.
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, and then replace Bucket.
I have also included the link for your manual, where I found these instructions. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
