20 Most Recent
DeLonghi DHE90 Dehumidifier Questions & Answers
Dehumidifier Compressor is not working
this unit is very simular to an air conditioner except it has a humidistat instead of a thermistat.. if your handy with a continuity tester unplug the unit find the humidistat and check to see if its open or if its good then call the company at 1 800 322 3848 or contact the web site at
[email protected] Good Luck
My delonghi dem 10 dehumidifier is working and collecting water but but the pause is continuously flashing why is this
The flashing pause light on your DeLonghi dehumidifier indicates that the unit is in a defrost cycle. During this time, the compressor shuts off and the fan continues to run in order to thaw any ice that may have formed on the coils. This process typically lasts for 10-15 minutes before the unit resumes normal operation.
If the pause light continues to flash even after the defrost cycle is complete, it may indicate a problem with the unit's sensor or control board. In this case, it is recommended to consult the user manual or contact a professional for assistance with troubleshooting and repairs.
2/26/2023 2:11:51 PM •
DeLonghi...
Answered
on Feb 26, 2023
DELONGHI DH300P E3
The E3 Code, indicates that the air intake filter needs to be removed and cleaned. Be sure the unit is OFF and unplugged before removing the filter. Filter cleaning should be performed at least once every two weeks, as part of Routine Maintenance.
6/6/2020 6:44:27 PM •
DeLonghi...
Answered
on Jun 06, 2020
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
5/16/2019 10:55:04 AM •
DeLonghi...
Answered
on May 16, 2019
De longhi dehumidifier showing yellow light
Usually happens when the float valve is stuck in the down or up position try wiggling the handle to release or if the collection bucket is not sitting perfectly on the safety switch has to be down square I have the delonghi dem10 model always empty and unplug before checking
1/31/2019 4:45:46 PM •
DeLonghi...
Answered
on Jan 31, 2019
Good morning.
I have a DeLonghi
Are you worried as to why there is no Water in the Water Tank/Bucket at all?
Well, a few operational basics must be understood by you please.
For the unit to remove moisture from the air and draw water into the bucket/tank, the set relative humidity (%RH) must be below the current or ambient room relative humidity.
Attempt to lower or reduce the setting you have to a lower value and it should start collecting water in the tank.
Hope this helps
11/20/2017 11:49:11 AM •
DeLonghi...
Answered
on Nov 20, 2017
