My Tunturi T60 is stuck at maximum incline. It shows no error at all, but when pressing the button to move it down, the incline motor(?) makes a bit of a racket. The advice to reset or calibrate (stop + up buttons) when powering on after 10 minutes off, doesn't do anything. Don't want to resort to propping the back end up on bricks to get it level!!
SOURCE: lens retract problem
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: The riser on my Tunturi T20 is stuck on maximum
Phil, I have had the same problem today.
did you solved the problem already?
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
SOURCE: I have an Epic t60. The incline stopped working. I
Try to recalibrate the incline. Start the machine running, press the incline up button, then pull the safety key off. Release the incline up button and replace the safety key. The treadmill should go to maximum incline then minimum. after calibration is completed, retry the treadmill operation.
