20 Most Recent
Tunturi T30 Programmable Treadmill Questions & Answers
Tunturi treadmill displays 51
hi,
Do on thing press and hold the reset button for 4 to 5 seconds.
IF doesn't help then watch which display shows the error 51. Press and hold the corresponding (display) button and press the reset button and hold the two button pressed for 3 seconds.
ok
Running belt has creased badly, will I need new belt ?
Wow, this is weird, I've just come back from the gym and the guys there were 'fixing' a crease on one side of the belt.
They had the belt off the treadmill, and put a wooden board on the inside, with some weight plates on them, a few wooden blocks on the inside, so the belt looked like it was the same height as when it is fitted and then a wooden board and weights on the top.
By the time I'd finished my session, they were refitting it and it looked good, you could still see a slight dent, but not a full crease.
Hope this helps you and good luck.
My Tunturi Treadmill ramp is stuck in the top
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality
Press ‘ENTER’ to scan DATA LINES to verify display functionality
Press ‘ENTER’ to scan SACN LINES to verify display functionality
Press ‘ENTER’ to scan LED’s to verify display functionality
After pressing ‘ENTER’ the TIME window shows “test” and the
keypad functionality can be tested (the value displayed
changes when a button is being pressed)
Press ‘ENTER’ to enter IO mode (TIME display shows lift
motor potentiometer value, SPEED reads speed from speed
sensor and DISTANCE shows heart rate pulse)
Press ‘START’ to test lower board relay (a “click” sound)
and then press ‘ELEVATION UP’ for 2 seconds to increase
the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum
percentage 0%
Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value.
Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps:
1. Drive the lift motor to 0% from user interface (inclination display must be 0%)
2. Switch off the treadmill and unplug the power cable
3. Remove motor cover
4. Fold up the running deck
5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame
6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the
lift motor frame
Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Treadmill stops when i incline it
Start your unit without any body on it, then increase incline and see if the unit shuts down if it does not then the first thing I would do is lubricate the deck if no maintenance has ever been done on the unit refer to your owners for the procedure. After lubricating the deck proceed with normal operation of the unit. If this do not take care of the problem you may have a worn belt and deck thus causing too much power to be draw thus shutting it down.
Crank Bearings
Call Accel Fitness of North America they the distributors of Tunturi Fitness. call them @ 1-888-388-6887
