20 Most Recent
Tunturi C80 Elliptical Cross Trainer Questions & Answers
Stopped working. Does it have a fuse?
Probable cause could be your Control Board or your power supply, I would definitely check to see if that board has a fuse (most circuit boards for machines do have a fuse on them) It never hurts to visually inspect the board to see if does have one.
Before checking the board I would verify that the machines power supply is supplying the machine with enough power, if any at all and to also make sure that it is on a dedicated circuit and not a surge protector/power strip.
We would be happy to help you out in anyway :) by chat at
www.sportsmith.net or by phone at 888-713-2880
We look forward to hearing from you if you need our help!
Where does Power Cord plug in on a Tunturi R60 Rowing Machine?
It sounds like you're having trouble finding the location where the power cord for your Tunturi R60 Rowing Machine should be connected. I recommend checking the front frame of the machine thoroughly. It's possible that the plug may be located in a small or obscured location, or it may be covered by a removable panel. If you still can't find the plug, you may want to contact Tunturi customer support for assistance. They may be able to provide more specific guidance on where the plug is located on your particular model.
Tunturi T60 treadmill problems with the PSC
The PSC (Power Supply Control) error message on a Tunturi T60 treadmill typically indicates a problem with the power supply or the control board.
Here are some things you can try to troubleshoot the issue:
- Make sure that the treadmill is properly plugged in and that the outlet is functioning properly.
- Check the fuse or circuit breaker and replace it if necessary.
- Inspect the power cord for any damage or fraying and replace it if necessary.
- Check the control board and wiring for any damage or loose connections and repair or replace them as needed.
If the problem persists, it may be best to consult the user manual or contact Tunturi customer support for further assistance.
If you are unsure about troubleshooting or repairing the treadmill, it's recommended to have a professional fix it to avoid any injury or damage.
How to fix error e1 on tunturi rowing machine starfit r100
Error code E1 on a Tunturi rowing machine typically indicates a problem with the resistance system. To fix this issue, try the following steps:
- Check the resistance settings to ensure they are set correctly.
- Make sure the resistance knob or lever is not loose or damaged.
- Check the flywheel and belt to ensure they are properly aligned and not damaged.
- Make sure the machine is properly lubricated.
- Check the power source and ensure the machine is properly plugged in and turned on.
- Try resetting the machine by unplugging it for a few minutes and then plugging it back in.
If the problem persists after trying these steps, it may be best to contact the manufacturer for further assistance or to schedule a service appointment.
MY TUNTURI J8F NON START AND DYSPALY ERROR 13. CAN YOU HELP ME?
If your Tunturi J8F treadmill is not starting and displaying an error code 13, there may be a problem with the treadmill's control panel or other internal components.
Some potential causes for this problem include:
- The control panel may be faulty. If the control panel is not functioning properly, it may not be able to start the treadmill or display the correct error code.
- The wiring for the control panel or other components may be damaged or disconnected. Check the wiring to ensure it is secure and in good condition.
- The treadmill's motor or other internal components may be faulty. If the motor or other components are not functioning properly, the treadmill may not be able to start or operate correctly.
If you are unsure how to check for and address these potential causes, you may want to consult the user manual for your Tunturi J8F treadmill or contact the manufacturer for assistance.
Motor Drive Belt Tunturi J620P Treadmill
Please check with Mcmaster carr, ebay and amazon to find your treadmill part. You can also check out alibaba if the 3 prior sources don't work out for you.
Thank you.
