No
to pair ac generators you have to get the cycles exact or they will destroy each other
that is to say that you you had a cycle meter for each gen set and could see where the sine wave was on each , then at the right time you could switch on the second genset and have an out put of 5.5 kw but as that is not possible then you cannot pair the two
SOURCE: 2000 chevy blazer won't get over 2200-2300 rpms and has whistle
kinda sounds like the catilist in the converter is bad and the exhaust cant get out
i cross referenced the spark plug (LD A7RTC)
and got the NGK equivalent:
SKU: #CR7HS
ITEM : # NGK7223
BRAND : NGK
Then got the specs off the NGK site
NGK 7223 CR7HS Nickel Spark Plug
It should be a 5/8" (16mm) spark plug socket.
