Question edited for a LOT more clarity. full 'make model (what it is)'.
Question moved from Computers to Model category.
Remove the batteries from both indoor and outdoor unit. Leave them out for 10 minutes. Replace the outdoor sensor with a new battery (2xAA), and then new batteries in the main unit (3xAA).
AcuRitehttps://www.acurite.com > media > manuals > 0...
PDF
NOTE: When replacing the batteries for the wireless sensor, remove the batteries from the sensor and clear that sensor's channel on the main unit by pressing ...
6 pages
Place your remote temperature sensor and the inside unit together for about an hour to see if they both read the same or if there is a large difference in the temperatures.
Dashes on the outside temperature reading may indicate that the inside unit is not receiving a signal from the remote. Change the batteries on the remote or change the location of the inside and/or outside units so that they can receive a strong signal between each other.
Your smartphone temperature may be coming from a location that is not near your home. They are often from a weather service. Where is your local temperature sensor located? Is it in the sun? Is it on the south side of the house, or another location where the sun or an air conditioner or other heat source may affect the accuracy of the reading? Try to locate your outside sensor in a shaded location with plenty of ventilation, and away from heat sources.
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below. 1. Bring both the sensor and display unit indoors and remove at least one battery from each. 2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor. 4. Reinstall the battery in the display unit. 5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected].
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
I had same problem. Take all batteries out of both units. Put the batteries in the remote sensor FIRST. Then put batteries in the main unit. Within five minutes, they will link up. Problem solved!
