if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling.
there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
