20 Most Recent Hotpoint FFA60 Bottom Freezer Refrigerator Questions & Answers
FFA45W
Hotpoint FFA47X fridge/freezer. I have had this fridge for 3 years now and has always on regular occasions decided to defrost when it feels like it and asks me to consume all the food immediately! I have wasted massive amounts of money on food and calls to hotpoint and have had a hotpoint engineer out to sort the problem about a year ago. It goes fine for a few months..then it defrosts all over again! Its just done it again, luckily I am not using the freezer anymore it only had some peas in there. Has anyone had this problem and solved it?? I would really like to use my freezer again but am loosing patience with hotpoint! I'd be very grateful for some advice.
12/30/2021 2:22:04 AM • Hotpoint FFA60... • Answered on Dec 30, 2021
3answers
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first: Red light on for High Freezer Temperature Warning or freezer not cooling, but fridge is and a lot of noise from compressor. Also, fridge drain hole blocked, water in bottom of fridge. This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut. 1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal. 2. Open freezer door and remove all drawers. 3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out. 4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor. 5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor. Warning: Be careful using electrics around water & melting ice & drips. 6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear. In the fridge, clear the drain hole in the same way. Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount. 7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
7/19/2019 9:11:35 PM • Hotpoint FFA60... • Answered on Jul 19, 2019
Water on the bottom of the fridge - then turning in ice
drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
10/14/2014 12:25:11 AM • Hotpoint FFA60... • Answered on Oct 14, 2014
0answers
On/off button
unplug ref. for a minute then try it.
11/9/2013 2:59:20 PM • Hotpoint FFA60... • Answered on Nov 09, 2013
Hotpoint fridge ffa60 red light on not sure what to do
fridge is freezing but freezer isnt how can i set my tempature
12/19/2012 9:23:26 PM • Hotpoint FFA60... • Answered on Dec 19, 2012
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
12/19/2012 7:17:59 PM • Hotpoint FFA60... • Answered on Dec 19, 2012
The lights won't work after I ch
What is the model number of the unit?
11/10/2012 7:55:30 PM • Hotpoint FFA60... • Answered on Nov 10, 2012
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
116 questions posted
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Refrigerators
Most Popular Question
hotpoint fridge freezer green red light
  • Refrigerators
