SOURCE: bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
SOURCE: bridge subwoofers
Without looking up the individual specs of your speaker and amp, I'll offer a few basics when it comes to bridging an amp.
Most important...find out what impedance (ohm) that your amp can handle bridged!! If you go below this rating, you will run the risk and most likely eventually overheat and short circuit the amp. You must also know the impedance of your sub (which can come in a variety) to be able to match them. Depending on this impedance match-up, it may be less beneficial to bridge the speaker to this amp. For example if there is an impedance mismatch you'll either get less power from the amp or short circuit the amp. If you know these I can help you come up with the best solution.
If you know bridging is the best option, then you'll have to know which terminals on the amp to use in order to bridge. This is how it normally works. On a 2 channel amp...you would normally take the positive from one channel to the positive on the speaker, and the negative from the OTHER channel to the negative on the speaker...and this is how you bridge the amp. The other two channels would remain UNCONNECTED. BUT!!! you have to make sure you use the correct 2 channels...it varies from manufacturer. But take heed not overload the amp...and not to overpower the sub. There are a few different ways that you can configure the subs if you find it beneficial to bridge your amp, these would take long to explain and would depend on the impedance of your subs and specs of your amp...these wiring configurations is how you match the impedance of the speakers input to the amps output (and is very important to do correctly) Look up "parallel and series" wiring configurations. Let me know if this helps, or if you need further help. Find out the impedance of your subs and the specs of your amp and i'll be able to assist you more. Hope this helps.
SOURCE: how do you wire four 12 inch kicker cvr dual voice
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
SOURCE: I have 2 1300 watt 12inch subs connected to a 2
It's trying to tell you the impedance is too low when you bridge. Run the speakers in series, not parallel.
SOURCE: kicker subs hook up problems
Connect one to each channel, for the best sound.
Testimonial: "thanks"
