The port engine is not coming up to speed properly. I seams like the turbo isn't engaging or the injectors fouled. If I work the throttles I can get it to catch and then come up about 3400 rpm. I've checked all water filters and sea strainers with no issues. any suggestions?
SOURCE: Engine won't start after running at cruise for 2 hours.
verifica la precion de gasolina es el regulador de precion.
SOURCE: My 2001 Ford F350 diesel
I'm assuming that this is an intermitent fault; are you make an scanning fault codes? Several items here, O2 sensors, camshaft, MAF/MAP, IAC, fuel pressure, bad injector, etc.
This is the firts step, check the OBD codes for knowed exactly what fault is there.
Tell us news.
SOURCE: 2001 PT Cruiser: my 2001 pt cruisers check engine light will not co...
GET THE CAR SCANNED FOR ERORS ON ANY ELECTRIC PARTS THAT MIGHT B FAULTY OR BROKEN
SOURCE: Galant 4G63 Non Turbo 2.0 Litre 1988 ... has bad
sounds like its breaking down, check your ignition system, test your leads, check your plugs, check your ignition coils etc etc etc.
Testimonial: "Proof in the pudding - the engines performance has totally changed with a simple but hidden leak in the intake manifold area ( now sealed ) ."
Removal & Installation
