SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: C-D370 error code for Copier KONICA-MINOLTA C252
this has to do with what they call NAVRAM IS C
To troubleshoot the error:
1. Reset the code by pressing stop-0-7-1-3-9. This will display a "*" on the LCD. Press this button.
2. Perform a Data Clear and then perform the Setup Procedures from the beginning.
3. Perform a NVRAM Recovery Procedure. Please see attached document. To view the PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for free from RRUPTED/need to be reset BUT that will clear all the current setting especially if print to it.if you are willing to try ....
you should have a Tech do this...
good luck
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one.
code will remove.
wish you best of luck............
SOURCE: Konica Minolta Di2510 error code C0500,can not
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Contact for Konica minolta, Canon copier for repairing/rental/amc/fsma.
We provide CANON IR SeriesDIGITAL PHOTOCOPIER for rental basis also, our rental prices per month 3500/- with free 10,000 copies pre month.
New Delhi & NCR.
Gaurav Pahuja : 9811139117, 9990258388
