20 Most Recent Konica Minolta DiALTA Di183F Copier Questions & Answers
C03FF Minolta bizhub 163
make the correct setting for "Model Setting"of "Adjust" available from the Service mode. copier thinks its one model and another part thinks it a different model Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 8:06:22 PM • Konica Minolta... • Answered on Mar 10, 2018
Clearing consumable maitenance
mam/sir Meter count, stop 00 stop 01 depress 3 counters 2, pm counter Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/4/2016 8:33:59 AM • Konica Minolta... • Answered on Jul 04, 2016
Clearing maitenance dialta 152
meter count, stop 00 stop 01 depress 3 counters 2, pm counter Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/4/2016 8:33:26 AM • Konica Minolta... • Answered on Jul 04, 2016
Service mode clearing maitenance
utility stop 00 stop 01 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/4/2016 8:28:27 AM • Konica Minolta... • Answered on Jul 04, 2016
2answers
Fiery pi6200 error code loading system
6/26/2016 10:30:09 PM • Konica Minolta... • Answered on Jun 26, 2016
Cof32 & coo7o minolta bizhub 210 how can i reset it?
sir/Mam C-0070 is the toner bottle, remove it, power off the machine, then with the bottle out turn the machine on, let it go thought its routine when it ask for toner install it PROPERLY if the knub on the bottle dented damage in anyway replace do not use the damaged bottle. the C0F32 is the toner is not properly mixing in the the developer because it is not getting any toner see above, Might need to replace the developer also Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/8/2016 3:11:19 AM • Konica Minolta... • Answered on May 08, 2016
Codico C0500
sir/mam First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/15/2016 10:46:51 AM • Konica Minolta... • Answered on Jan 15, 2016
C 13f8
replace the print head which houses the machine LASER Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/14/2016 3:45:09 AM • Konica Minolta... • Answered on Jan 14, 2016
I need the Konica Minolta Di470 Driver fo Windows 7
Its a legacy minolta machine but try this site Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/14/2016 3:30:50 AM • Konica Minolta... • Answered on Jan 14, 2016
Error 0f 2 di183f
please resend the code Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/13/2016 11:34:09 PM • Konica Minolta... • Answered on Jan 13, 2016
Como reseteo
utility, stop 00 stop 01, use arrows to select service adjust set machine to 18 PPM (page per minute) Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2016 3:58:30 AM • Konica Minolta... • Answered on Jan 10, 2016
Minolta di2011 show c0000
main motor failure remove the image unit check gear pack toward rear right side of image unit. mite have a bad motor also Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2015 2:42:55 AM • Konica Minolta... • Answered on Dec 30, 2015
Reset bizhub 163
what code???????????????????????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/30/2015 7:34:07 PM • Konica Minolta... • Answered on May 30, 2015
Which code on button of an ADF showing error
do not understand? what code? ADF error? what error? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/25/2015 9:14:31 PM • Konica Minolta... • Answered on May 25, 2015
Dialta di 2510 codice cos 32
Replace the developer. If that does not work replace the ATDC sensor located under the image unit. Has multi-color ribbon cable. If not that then the main control board if you can find one. Best bet would be replace the developer and ensure you clear the counter for develop and run the F8 process after replacing the developer. DO NOT USE A VACCUM CLEANER to replace the developer because the static electricity from the vacuum cleaner can destroy the sensor. Also the copier uses the counters to adjust voltages for certain assy. so if you replace the developer and don't clear the counters then the machine will adjust voltages for a used drum or developer when in reality the developer or the drum are new. Causing image problems and codes Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/17/2015 4:38:51 AM • Konica Minolta... • Answered on May 17, 2015
Di470 code c13f7
C-13F7 code hai
11/2/2014 10:01:56 AM • Konica Minolta... • Answered on Nov 02, 2014
Di2510 toner bottle is not rotating
must have the block that turns the botle toner it works well remove the toner click on f8 and watch the block rotates or not
6/3/2014 12:24:20 PM • Konica Minolta... • Answered on Jun 03, 2014
I need the Konica Minolta Di470 Driver for Windows 7
http://www.konicaminolta.hk/hk/en-us/download-license-agreement.php?rtn=http%3A%2F%2Fwww.konicaminolta.hk%2Fhk%2Fen-us%2Fdownload-driver-download-result.php%3Fsearch2%3Dtrue%26category%3D-1%26subcategory%3D-1%26product%3D-1%26os%3D-1%26emulation%3D1%26p%3D6
6/1/2014 2:21:00 PM • Konica Minolta... • Answered on Jun 01, 2014
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove. please always mention the copy counter and life of consumables every time when ask the qustion.
3/20/2014 6:02:44 AM • Konica Minolta... • Answered on Mar 20, 2014
Konica Minolta DiALTA Di183F Copier Logo
73 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
black streaks
  • Office Equipment & Supplies
