My self starting Prado is now on snapchat or youtube starting by itself over and over...
SOURCE: '91 honda accord battery light on with new battery.
either your alternator has gone or your fan belt is not there which helps the alternator to charge the battery get a volt meter on your alternator to see if it is kicking out what it should be
SOURCE: 92 honda accord Has gas Started and died like
replace fuel filter first check fuel pressure.
SOURCE: 91 Accord Car will initially start then when
I have a 1991 honda accord dx that had the same problem. while driving it would just completely shut down. after about 5 minutes it start and run for a while then shut down again getting more frequently. There was a recall on the ignition control module (ignitor) which is in the distributor. call your local honda dealer with your vin # and will tell you if yours was replaced. If not I bought one from parts store for $60 or you could take a chance and buy one from a junk yard. I bought the whole distributor for $20 as a back up.
SOURCE: my car started dying and now hasnt enough charge to start
sound like bad battery cables.replace them.the positive battery cable is old and have a lot of resistance not allowing power to the alternator to charge battery.if battery cable good check alternator connector wires.make sure they are not damage also check alternator fuse and fuse link.turn off radio before removing battery wires so you wont lose radio code.
SOURCE: Toyota Prado Diesel. Electric windows do not operate
Hello! Turn the ignition switch on...Hold the master power window auto up switch for five seconds...Send a comment with results...
Guru........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Hi Linda, I had the same nightmare last night my Prado tried starting itself over and over again. Battery went flat and then alarm started going off. What did you end up doing and what was the fault etc please:)Im happy for you to email me on [email protected]
