Computers & Internet Logo
James Collins Posted on May 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the back panel from an MSI Optic G27c monitor?
The monitor fell and the bottom corner of the monitor popped out from the front panel. I need to remove the entire back panel and reinstall it. I removed the 3 screws at the bottom of the monitor, but can't figure out how the back plastic housing is removed.
Larry Ng
Level 3:
Top Expert:
  • MSI Master 14,606 Answers
  • Posted on Mar 23, 2022
Larry Ng
MSI Master
Level 3:
Top Expert:
Answers
14606
Questions
0
Helped
3280942
Points
66651
Most monitors made have no service guide, and if exists are only sold to authorized shops, MSI
the base is removed first completly
the all seen screwns
then thing pry part, no to monitors do this the same way.
5 Related Answers
Anonymous
  • Posted on Mar 31, 2009
SOURCE: Acer 1717 monitor- removal of base
At the base you want to remove - in order to pack the monitor - if you se at the rear left and right there are a tiny opening about 3 cm long,put inside a screw driver and it will open very easly the plastic cover.Then inside there are four screws,two on each side,remove them and the arm of the screen will be dis-attached.
Anonymous
  • 5911 Answers
  • Posted on Jul 05, 2009
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
protek480
Craig Butler
  • 1730 Answers
  • Posted on Sep 17, 2009
SOURCE: i need to replace drum belt in whirlpool ggw9200lw
Watch the video, it will help you see how.
http://www.youtube.com/watch?v=9dd1Ac4_pXY
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
crash_59
Chris Nomland
  • 124 Answers
  • Posted on Feb 09, 2011
SOURCE: when i removed the bottom
I( think Dirt devil wheels are held on by a little clip, kind of round ish. Check the other wheel and see if it has that kind of set up. Chris
william rodriguez
  • 958 Answers
  • Posted on May 04, 2014
SOURCE: how do i remove front panel on a Whirlpool wfw96heac
I have a whirpool duet qnd to get the front panel off you have to take out the soap drawer and there is a bolt there that has to come out.
also I had to pry off the trim piece around the control panel to get to the rest of the bolts. I did it carefully and it came off without breaking.
I need to replace the water level switch. I don't know how to remove the control panel cover
Hello, If its a top load there are screws either on top of the back panel or two screws one in each corner of the bottom rear control or clips in the front where you slide a putty knife under each corner and pop it up.
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
3helpful
How do i replace the door boot seal?
j
  • 7mm socket
1helpful
Driver's side window fell off the track and into the door. How does the door panel come off after removing the screws?
Starting at the bottom rear corner, pull the door panel away from the door. Sliding you finger along the bottom, continue to pop the clips from the door. Once you have all the bottom clips undone, work your way up the sides. Once those are all popped, you lift the panel upward toward the roof and away from the door, toward you.
Installation is the reverse of removal.
1helpful
4answers
HP 2210 has a problem with the inside of the glass so photo/doc are fuzzy and unclear when scanned. Is there a way to clean the inside of the glass?
there are 3 screws, one's at the left side of the unit on the top corner (this is the one that's visible), the other 2 are under the silver cover, which houses the dial panel and the LCD, in order to remove the panel you have to use a flat head screw driver or something like that, and pop out the dial cover starting from the top right corner then the left side and eventually the bottom part, and then, using something that can fit through the square hole near the bottom of the dials under the cover which you've just removed, press the lock inside and simultaneously pull(slide) the panel towards the front of the unit, there then you will see the two other torx screws
Good Luck
Mohamadreza
3helpful
2answers
Front door panel removal
There is a triangular piece, at top corner, covering a screw behind the mirror. Remove that screw. Remove the piece that covers the handle and remove the screw holding the handle to the door. Look through, where door handle was and remove another screw just above where the handle was. This screw is holding the panel to the actual door. Pop the cover off for the automatic door locks and disconnect them. Lift the panel in an upward direction.
Removal of front cover
To remove the front cover you need to start by putting the monitor down flat on its face on something that wont scratch the screen.
Next, remove the screws holding the base to the back of the monitor. (You might need to remove a plastic cover to get to the screws).
Once you have done this check for a screw under where the base was screwed on. Remove this screw.
Now check the back of the monitor for one screw in each corner. Not all models have these 4 screws,if they are there, remove them.
Now the front and back of the monitor are held together with plastic clips. You will need to gently pry the front and back apart.
Its easiest starting at the bottom middle and working around.
Once you have separated the front and back, the inner circuitry is exposed. The control panel for the unit can be removed by unscrewing 3 screws that hold it in.
Kenmore gas dryer model 11070812990
Take a flat-blade screw driver and stick it in the seam between the top cover and front panel at one corner and pry up. The top panel will pop up from the catch - then do the same for the other front corner.
You can then tilt the top up towards the back of the dryer because there are hinges in the back. Spin the drum to where the holes for the baffle are and screw the baffle back on. If you are missing the screws, they probably fell to the bottom inside.
You can take off the front by unscrewing the two screws that hold the top of the front panel to the outside panels. Once those are off, just lift the front panel straight up and pull away. There are two holders towards the bottom that the front panel slides into.
Once the front is off you should be able to find the screws below.
Good luck. . .
Will not drain
If your GE Washer is like mine all you need to remove the front is a 2 inch putty knife. Insert it in the seam between the top and front panel about 6 inches from the corner. You will find a clip there. Push the clip backwards with the putty knife while pulling gently on the corner of the front panel, the clip will come loose and the front panel will come froward on that corner. Repeat the procedure on the other side and the front panel will come right off. To put the panel back on just insert the bottom of the panel in the bottom clips and snap the top right back into place. This makes access to the inside of your GE washer a breeze. Before doing this always disconnect your electrical plug.
Dave
9helpful
4answers
Is there an easy way to open this monitor?
-Flip the LCD face down and remove the screws that hold the base in place. -looking at the top edge of the LCD monitor you should see a small notch on each end between the front bezel and the back cover. -Using a plastic tool or a flat blade screw driver insert the tip and gently pop the case open. -Work your way around the edge of the case. -Once the LCD monitor is open unplug the control panel connector from the right side and remove the front bezel. Let us know if you have any other questions and please don?t forget to rate this post.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
