Washing Machines Logo
R
RANA Posted on Apr 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sammi James - FIXYA expert spammer - how to solve issue my samsung washing machine model WF602W2BDBDQW SHOWING ERROR ue
bvmihai
Level 2:
Sergeant:
Habit-Forming:
  • Expert 177 Answers
  • Posted on Apr 29, 2018
bvmihai
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
177
Questions
0
Helped
99390
Points
510
The UE error mean unbalanced error. Check the link below to find how can you fix it http://www.samsung.com/uk/support/home-appliances/my-samsung-washing-machine-is-showing-a-ue-code-during-a-spin-cycle-what-can-i-do/
All the best !
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Jan 29, 2008
SOURCE: LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
Anonymous
  • 57 Answers
  • Posted on Jun 24, 2008
SOURCE: code error ue lg washing
ue is (imbalanced error) cause. the load is to small,washer is tilted, laundry is gathered to one side, non distributed things are put into the washer
Anonymous
  • Posted on Dec 14, 2008
SOURCE: LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Anonymous
  • 355 Answers
  • Posted on Jun 16, 2009
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Anonymous
  • Posted on Mar 12, 2010
SOURCE: Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
2answers
Sammi James is a horshite assholI fuqhead My samsung top loader of 13kg shows code dE
Many Samsung top loader washers are recalled due to a severe unbalance issue that causes the top of the washer to become dislodged and fly off. Enter exploding Samsung washers in your search engine. Since your machine may be recalled, you may have a free service call coming your way anyway!
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
My washing machine shows UE errors
The UE Error Code indicates that the laundry load is unbalanced. Just redistribute the load and when you shut the lid it should start to re-spin again. On some machine you have to push the start button.
Could Sammi James be from India, too? Sammi James - expert spammer is back again - at least no fake phone numbers! Samsung 63 Inch TV 1080p Plasma HDTV line across
You have dead pixels , It may cost more to fix than getting a new tv, ill recommend calling samsung and talking to them to see if your still under warranty. Thanks -JC
1-800-SAMSUNG (1-800-726-7864)
Mon - Fri: 8am - Midnight (EST)
Sat - Sun: 9am - 11pm (EST)
Sammi James - expert spammer is back again - at least no fake phone numbers! code for samsung sgh-z107v unlock network
To unlock your Samsung SGH-Z107 mobile, visit this site Theunlockspot.com. Before unlocking, You need to provide the details of your's mobile IMEI number, Country and Service Provider. Finally you can get the unlock code for your mobile and use it.
Sammi James - expert spammer is back again - at least no fake phone numbers! how to reset my file pass word s5620
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
What does"ue " mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
9helpful
What does "ue'"mean?
1helpful
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL [email protected]
2helpful
Letters UE on display
UE = Unbalance Error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
