I have a refurbished Lexmark x4270, and when a fax is coming through, it stops because there is a remote fax error. What does this mean? I it my fax or the fax machine sending the fax?
I have a lexmark x4270 all in one. I can receive a fax, but get a remote fax error when I need to fax to my workplace. How can I fix this?I have a lexmark x4270 all in one. I can receive a fax, but get a remote fax error when I need to fax to my workplace. How can I fix this?
AnonymousMar 20, 2014
Having problems resetting date and time on my Lexmark. Any Suggestions? Also sending 9 pages out of 10 and stops at 9 with Fax Error showing on LED. Any Suggestions?Having problems resetting date and time on my Lexmark. Any Suggestions? Also sending 9 pages out of 10 and stops at 9 with Fax Error showing on LED. Any Suggestions?
You can't post conmments that contain an email address.
Check under control panel/printers and fax/select your fax, then see if you can "purge documents" it may be that some incomplete documents are still in memory, and need to be discarded.
The 1200 error indicates the cartridge carrier has stalled. It could be caused by a cartridge that's not properly seated or the encoder strip (transparent strip behind the cartridge carrier) is out of place. Refer to this article from the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-Oneto help you identify and resolve the problem.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Here's an article in the Lexmark website that will guide you on what to do when have Error 1203 on the printer. Just click on this link: http://bit.ly/ax8swM. Make sure to follow the instructions carefully. But if all else fails, I suggest you contact Lexmark at 1-800-LEXMARK (1-800-539-6275).
Does it only happen going to one certain fax destination or every destination? There are some things to try on the Lexmark web site.
Go to www.lexmark.com and click Support->Technical Support. Type in 4270 in the 'Search by Model' box. Type in 'Remote fax error' in the 'Search the Knowledgebase' box. There is a topic called 'Problems Sending a Fax to Specific Fax Machines' that has some good general tips.
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
I have been sending and receiving faxes for over a year on my Lexmark X6100 printer. Now whenever I try to send a fax it will say it is sending the pages but then waits for a redial. After doing the same thing a second time it will print out "remote fax error"
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
Power the printer off.
Remove all cables from the back of the printer.
Reinsert the power cord.
Switch the printer back on.
Check the operator panel to see if the 1201 error message is displayed.
If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
fax says failed to connect and dont have instru. sheet any more.
