Dishwashers Logo
M
Misha Lowenstein Posted on Mar 15, 2018
Why is my viking 4 amp high charger blinking 00 v?
4 amp Viking battery charger has the clamp symbol blinking and won't charge battery
IN CAR
CONNECT TO BATTERY AND NOT HAVE CAR BATTERY CABLE CONNECTED,
HE CHARGER HAS BRIAN THAT WE ALL KNOW IS TINY AND LAME. OR SMARTER THAN THE AVERAGE BEAR.
IF THE BATTERY HAS 1 WEAK CELL IT , MAY SHUT OFF.
THIS IS TO PREVENT BATTERY EXPLOSIONS.
EVEN CARS NEW, ALTERNATORS DO THIS TRICK./
USE A VOLT METER, AND CHECK BATTERY VOLTAGE FIRST, IF AT 10V A CELL IS OPEN OR SHORTED,AND BOTH ARE BAD NEWS,. EOL OF BATTERY.
REPEAT THE TEST WITH BATTERY LUGS PULLED.
USE A VOLT METER.
OLD RELIC CHARGES DID NOT DO THIS, IT WORKS NO MATTER WHAT AND ON SOME A BAD BATTERY OVERHEATED FAST. BUT 4AMPS IS (TINY)
2helpful
2answers
Huskeystar Model 50 - I have inherited this machine with no manual. I can't find anything about the machine on the internet.
Contact Husqvarna/Viking
Machine support
Toll free 1.800.446.2333
Monday – Friday: 8:00 am – 4:00 pm CST
[email protected]
2answers
Viking battery charger is flashing does that mean its charging
Depending on the color the lights blinking. Red light blinking usually means charging. Green light on or blinking usually means charged. If its blinking red and green, usually means bad, or defective battery.
I received my replacement dongle that was damaged from my dealer..it says this dongle already registered but I can't activate it..dealer says viking problem..viking says dealer problem...can you help
Hello, VaDonna -
Fixya.com has no affiliation with the Husqvarna Viking company or any of its sewing machine dealers.
Did you speak with a real person at Husqvarna Viking machine support about the dongle problem?
800-446-2333
Monday - Friday: 8:00 am - 4:00 pm Central Time (USA)
Best wishes.
2answers
My Husqvarna designer SE is not telling me bobbin is empty
Hello, Dene -
Go to this Husqvarna Viking Desinger SE Troubleshooting website:
http://www.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_SE_Troubleshooting_EN.pdf
Scroll down Page 1 to the section with the heading "Bobbin Alarm Does Not Work? Follow the instructions there.
If those steps do not get your bobbin sensor back in working order, I suspect you will need to have the bobbin sensor repaired by an authorized Husqvarna Viking sewing machine repair service.
I suggest you contact the Husqvarna Viking sewing machine dealer nearest you and ask about authorized repair businesses.
You can also contact Husqvarna Viking directly:
Monday - Friday: 8:00 am - 4:00 pm CST
[email protected]
The presser foot icon flashes and machine will not sew
http://www.husqvarnaviking.com/en-US/Support
https://www.sewingpartsonline.com/viking-1250-sewing-machine-parts.aspx
call Viking at: 1-800-474-6437 if it's out of print for a photo copy of the original owners manual.
1helpful
My laptop turns off when charged
Computer restart due to overheating:
Computer restarts due to over-heating when the processor fan goes faulty.Computer restart due to faulty RAM:
Computer restarts abruptly if RAM goes faulty, or if you install some in-compatible RAM or more than one RAM modules of different frequency or type.
Computer restart due to faulty Hard-disk:Faulty hard disk is one of the most common reasons for abrupt computer restart. Run a hard disk scan to fix this issue. If there are bad-sectors on your hard-disk, its the time to get it replaced. Computer restart due to overheating up of hard-disk:
1helpful
I do not have a problem. I would like to know if there is a user manual or guide for QuiltSewClever. I did not get one when I purchased my product with my long arm.
They do not show a manual onlne but here is there contact info:
Contact HUSQVARNA VIKING®At SVP Worldwide, we take pride in taking care of our customers. Your dealer is trained and qualified to help resolve any issues that you may be having with your machine, your first step should be to contact them directly.
Your comments and concerns are important to us. Please feel free to contact our Consumer Affairs department should you require additional troubleshooting assistance. You may email, call or write us. Please provide your model number and serial number when contacting us.
Email: (Please allow 72 hours for response)
[email protected]
Call:
Toll free assistance - 1-800-446-2333
Monday-Friday 8:00 am - 4:00 pm CST
Write to:
SVP Worldwide
C/O Husqvarna Viking
P.O. Box 7017
LaVergne, TN 37086-7017
Embroidery Software Support:
For assistance with your HUSQVARNA VIKING® 5D, 4D or 3D Embroidery Software, or for HUSQVARNA VIKING® Embroidery Machine communication.
Monday - Friday: 8:30am - 9:00 pm Central
Saturday: 10:00am - 2:00 pm Central
Phone: (615) 280-3510
FAX: (615) 280-3410
Click here to for your Software Support Request
HUSQVARNA VIKING® SOS
SOS provides extended support and education for your HUSQVARNA VIKING® 4D and 3D Embroidery Software. SOS Membership includes unlimited Toll-Free phone calls, remote and email support, newsletters, projects, and E-Learning. Learn More
Click here to learn more about SOS
8helpful
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Top Viking Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
