Sewing Machines Logo
R
Ron Advice Posted on Mar 13, 2018
I have a white sewing machine model 1955. how do I adjust foot to center
5 Related Answers
Anonymous
  • 323 Answers
  • Posted on Dec 29, 2008
SOURCE: foot pedal assembly for White sewing machine
You only need to replace the cord if it has been damaged. It will cost less if you just take the machine , cord and control to a local technician and have him just replace the foot control. Let him test it first. A generic foot control should cost less than $30.
sewman7
Anonymous
  • 231 Answers
  • Posted on Jan 04, 2009
SOURCE: white sewing machine model 2999
Winter 2002 was when it was first released. Retail of $499.00.
Contact White Sewing Directly for parts =>
http://www.whitesewing.com/customer.asp
Anonymous
  • 9 Answers
  • Posted on Feb 21, 2009
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Anonymous
  • 15 Answers
  • Posted on Apr 15, 2009
SOURCE: sewing machine maintenance, walking foot & free-motion foot
Is this a Janome MemoryCraft 9000? (I ask because the models seem to get mixed up in the threads)
If so, you can more than likely find accessories for the MC9000 either on eBay, your local Janome dealer (you can find the closest one to you @ Janome's website using the "Dealer Locator" feature) or even ... SEARS!
Sears contracted Janome to make several of their sewing machines (I think Janome might still be the actual manufacturer, but aren't 100% sure) and so the parts are compatible. You can even use a Kenmore Memory Card with a Janome MC9000.
As for oiling, if it's the MC9000 (much like practically all newer models) they don't need oiling. Though sometimes, you can dab a teeny-tiny amount of oil on the bobbin case if it needs it.
ken dourof
  • 980 Answers
  • Posted on Mar 28, 2010
SOURCE: Looking for manual for White sewing machine model # 311
try www.sewing-machine-manuals.com and click on relics.
Adjusting position of pressure foot, needle not in centre of pressure foot
Unable to assist without knowing the make & model machine. You can search the internet for:
Make Model presser foot pressure
Make Model center needle..... (or something similar)
Why is needle hitting zipper foot on left side only?
When the needle is set on the center position, is it centered or is it slightly off center? If so, then the mechanism needs to be adjusted so that the needle is perfectly centered. When it is off-center, you will get the problem you are experiencing with hitting one side of the zipper foot. May want to take it in for service.
Looking for zip foot for 1948 White sewing machine
check with these sites for parts, call or email
sewvacdoctor.com
a1sewingmachines.com
Have white sewing machine model 1866, it keeps binding up, the foot feed will not move like it should, is there an adjustment somewhere? is there an online manual somewhere?
On the singer website on the home page look for
Instruction manuals at the bottom of the page-click on it
Put in your model number w1866 & click search
My white sewing machine needle keeps breaking.
take it to a sewing machine repair shop, so the needle bar can be checked, & also the timing
I have a White sewing machine, model 1866. what
There are two types, the foot itself is very thin with a groove either side and the other type is the same as above but with an adjuster on the back of it
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
