SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
SOURCE: my over the oven model 665.61629100 kenmore has cracked door
The outer door frame CAN be replaced if you like. You can view an exploded view diagram at searspartsdirect.com. Just type in your model number and locate item 10 under the "Door" parts listing. The part comes in various colors so make sure you select the correct one.
The door can be easily removed by opening it all the way and lifting straight up at the hinges. The door will come off the hinge pins and can be laid on a flat surface for easier access. Place a layer of towels under the door to prevent damage to the door.
You will need to remove the door handle to get the outer door frame off. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you may need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and and locate any screws that may be securing the outer door (front) frame in place. Once you install the new outer door frame, re-install the door handle and carefully re-insert the inner door panel. Gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
To answer your initial question, the microwave should continue to be safe to use as long as the inner door seal and door glass are intact. Make absolutely sure you reinstall the door components back together properly. Not doing so will render the oven unsafe to use. Refer to the web site I provided as a reference for how the door components go back together.
NOTE: This part is listed a bit cheaper at appliancepartspros.com. Use the part number from the first website I mentioned as your search criteria.
SOURCE: frigidaire CFEF372BC2 electric range - oven door
Hi .The oven door will not unlock until it cools down despite the cycle being finished.If it has not opened in a maximum of 1 or 2 hrs then oven sensor failed during self clean cycle and will have to be replaced.Try restarting self clean to unlock door .If not you will have to do the old coat hanger trick or manually move the lock mech. from rear,sensor cost $30-40.Hop this helps .Please rate my response :)
SOURCE: Remove Outer Glass Of Oven Door
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Hello Pamela, thanks for your post!
From my understanding your Frigidaire range had an issue when it was in self-cleaning mode. It sounds like your thermostat or control panel may need to be replaced. I would suggest seeking help from a professional technician this will help you to avoid any unnecessary part purchases or improper disassembly of your range. Hopefully this information is helpful to you. -Matt
