LAVAZZA LB5010 Manuals
https://www.usa.philips.com/c-m-ho/coffee
Saeco / Coffee
1-800-933-7876
SOURCE: DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
SOURCE: Need Instruction Manual for Saeco Magic Comfort Plus
http://products.saeco.com/index.asp?id_paese=7
follow the link to the instruction manual
SOURCE: Need a repair manual for Saeco Italia Espresso machine
http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
at the bottom of this page u can download the manual
SOURCE: how do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
