20 Most Recent
Saeco Vienna Deluxe Questions & Answers
Machine does not make coffee and make a loud kicking sound
you have a problem with the gears of the mechanism that drives the brew unit. They are 2 in number and change easily if you can open the covers of the machine and remove it.
You can try to make the quantity of ground coffee a bit less . It can fix it for litlle period of time. But the gears must be changed.
Have a nice day
Does the boiler need replacing
Hi
its not the boiler. Its you brew head. Here is how to clean it.
Remove the brew unit. Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON'T use the key to install the screen, use your fingers.
Once the screen is out look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Weak espresso.
If you cannot adjust the grind any finer, youmight have to open the grinder and reset burrs or replace them.
Low water pressure
i had the same problem the brew unit was block from many shot remove the little tube on top of brew unit be carefull after removing the 2 screw there a spring under the tube and glass ball clean it good
I can't get the coffee grounds plastic dispenser back into the
remove the used grounds container and place a folded piece of paper where the grounds container touches the micro switch ( that is in a slot in the left side where the container enters approx 8cm inside) and then restart the machine and the grounds container will now be able to enter, remember to remove the folded paper before inserting the container
Saeco Vienna delux
The brew group is out of place.
The brew group cannot be taken out.
Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
Slow coffee drip
did you change coffee different coffee different setting lower our coffee setting move it only when it grinding only cheers
